stroking 2.2 to 2.5 opinions and advice welcome
Old Jun 24, 2006 | 06:12 AM
2slo2bst's Avatar
Default stroking 2.2 to 2.5 opinions and advice welcome
i have a a 99 lude 5spd.
I am considering stroking my 2.2 to 2.5 theres a company in new york tpocket rockets that sells a forged crank forged rod forged piston combo with rings and bering for 2600 . i know that ill have to sleeve my block advice from people who have stroked or know some who has stroked a 2.2 would be most helpful thanks
Old Jun 24, 2006 | 07:51 AM
JDMF22B's Avatar
Default Re: stroking 2.2 to 2.5 opinions and advice welcome (2slo2bst)
If i remember correctly the h22 has really think cylinder walls, and boring out that much isn't really the best of ideas. Most people wont go past 2.3 ... and most wont even do that
Old Jun 24, 2006 | 08:09 AM
The Birdman's Avatar
Default Re: stroking 2.2 to 2.5 opinions and advice welcome (JDMF22B)
You can look in my sig to get an idea of a stroked and bored h series.
Old Jun 24, 2006 | 09:13 AM
MLBZ521's Avatar
Default Re: stroking 2.2 to 2.5 opinions and advice welcome (jd3jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMF22B &raquo;</TD></TR><TR><TD CLASS="quote">If i remember correctly the h22 has really think cylinder walls, and boring out that much isn't really the best of ideas. Most people wont go past 2.3 ... and most wont even do that</TD></TR></TABLE>
That same place, Pocket Rocket builds or bores the H 2.2L out to a 2.7L that's a very big bore..
Old Jun 24, 2006 | 09:54 AM
hu's Avatar
hu
You will be okay with 2.4 or even close to 2.5. You can still keep a 89mm bore. If you use a H23 crank you should have displacement close to JDMJD3.
H22A/1/H23A1:
Sleeved Block/89mm bore
H23 crankshaft
Any off the shelf H23 rod
Any off the shelf 1.200 compression height H23 piston
That will give you 2364cc's and a r/s ratio of 1.49 (stock H23)
Or it you want to go bigger:
H22A/1/H23A1
H23 crankshaft offset ground from 1.888 to 1.771 (98mm)
Crower 5.564/.935/1.890 rod part # ML93723B-4
Custom 89mm 1.150 compression height pistons w/.827 (B series) wrist pin
That will put you at "0" deck
That will give you 2438cc's and a r/s ratio of 1.44
If you have the H22a4:
H22A4
F23 crankshaft (reworked to accept .935/1.890 BE bore (B series rods)
Custom 89mm 1.170 compression height pistons w/.827 (B series) wrist pin
That will give you 2413cc's and a r/s ratio of 1.45
Old Jun 24, 2006 | 10:06 AM
MLBZ521's Avatar
Default Re: (hu)
^^ Nice info..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">You will be okay with 2.4 or even close to 2.5.</TD></TR></TABLE>
^^ I agree with that also. From what I've read, 2.5L is about as big as you can take it before it becomes unstable/unreliable. Well, for long time use or something.
Old Jun 24, 2006 | 04:05 PM
2slo2bst's Avatar
Default Re: (hu)
hu ur stud i looked all over for somthing like that !!! I am calling darton on monday to see how much it would be for them to mideck my h22a4 bolck so form there i will decide witch way to go thanks for ill the info posted and will keep updating asi go along by the way hu dod you know any one who has used that combo ? if so what if any are major prolbems aside from costley machine work ? thanks sal
Old Jun 24, 2006 | 07:43 PM
hu's Avatar
hu
Default Re: (2slo2bst)
I am going with the 2nd option that I posted. My cousin is going with the first one, the H23 vtec bored to 89mm.
Contact PrecisionH23a. He is a member here. He does Darton work.
Old Jun 24, 2006 | 07:54 PM
h22 civic's Avatar
Default Re: (hu)
pocket rocket is a pretty smart guy from my experience with him,,,im pretty sure he also has a 3.0 stroker kit as well its the biggest 2.2 in the world i think
Old Jun 24, 2006 | 11:40 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (hu)
Pocket rockets made a 2.7 L H22 with (I think) 92mm offset bores. search his name you should find it. He has vids and dyno plots
Old Jun 25, 2006 | 06:19 AM
h22 civic's Avatar
Default Re: (cb7-R)
http://www.pocketrocketsracing.com/
one of the most knowlegable h22ers i know
Old Jul 8, 2006 | 07:13 PM
2slo2bst's Avatar
Default Re: (h22 civic)
so ive been working with frank at pocket rockets for about two weeks off and on i was all ready to send my block off to darton and franks says why dont you think about about one of my extended deck blocks he is making a 1/2 taller deck h22 block (better rod to stroke ) . has any one delt with a extended deck block i didnt realise that you could extend a block . the olny reason i ask is that ive never heard of it (so im a dumb *** ) . but after i ship off my block to darton get mid sleves and get it back the machine shop here still has to line hone and speck and mike will be about the same cost as the extened deck . assembled by pockets w/ the 2.5 insalled .
Old Jul 8, 2006 | 11:02 PM
Rosko's Avatar
Well, if its the same price then go for it. I've never had one personally, but yeah then you can use a longer rod and get a few more r's out of it safely. Frank seems to know his stuff, and the pics I've seen of his work prove it.
Kobane
Apr 27, 2008 09:49 AM
dblock2x
13
Dec 6, 2006 10:10 AM
Silkk Tha Shocker!
May 12, 2006 11:46 PM
sprayinrice
Feb 15, 2005 02:28 PM
01-0338R
Oct 2, 2001 07:14 PM
