does it increase wheel gap?
Old Jun 24, 2006 | 01:54 AM
budget's Avatar
Default does it increase wheel gap?
if your car is lowered on 16's with springs and pretty much has no wheel gap if you put 17's on there does it raise the wheel gap
Old Jun 24, 2006 | 07:05 AM
Targa250R's Avatar
be professional
Default Re: does it increase wheel gap? (555deal)
Depends on the tire sizes. If you maintain the same overall outer tire diameter, the wheel gap will be the same.
Old Jun 24, 2006 | 10:56 AM
budget's Avatar
Default Re: does it increase wheel gap? (Targa250R)
going from 205/50/16 to 205/40/17 what will that do
Old Jun 24, 2006 | 11:09 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 555deal &raquo;</TD></TR><TR><TD CLASS="quote">going from 205/50/16 to 205/40/17 what will that do</TD></TR></TABLE>
205/40-17 is a smaller diameter so it will make the gap greater.
But you should get the proper size tires for your car, with the same outer diameter as stock. If you have a Prelude which came from the factory with 205/50-16, then get tires that are roughly the same outer diameter, which means 205/45-17. If you have an Integra, then get 205/40-17 (or 205/45-16).
GoLowDrew
Mar 17, 2009 10:40 PM
JD95hatch
Aug 20, 2004 02:07 PM
rexgo
15
Nov 20, 2003 05:05 PM
Pineapple Devil
Aug 27, 2003 10:34 PM
CLICC916
Feb 13, 2002 01:38 PM
