better handling
Old Jun 23, 2006 | 09:45 PM
-Championship-'s Avatar
Default better handling
currently i have rear lower tie down bar (no name) rear upper strut bar (skunk 2)
front top strut bar (skunk 2) front lower strut bar (no name) and car is dropped about 1 1/2 inches..is there anything taht i can buy that can make my car do sharp turns..besides like 1200 dollar tein suspension..maybe sway bars?
Old Jun 23, 2006 | 09:48 PM
microsoft_sux's Avatar
TEIN is the ****! Look at larger diameter rear sway bars, upgraded lower front bar might help. Custom X-bars FTW!
Old Jun 23, 2006 | 09:54 PM
Default Re: (microsoft_sux)
x-bars?
Old Jun 23, 2006 | 09:58 PM
jdm_bones's Avatar
Default Re: (project_B18C1)
USE A JDM ITR SWAY BAR 23mm...best bang for the buck! Talk to passwordjdm, they keep them in stock! your from downey, so they are down the road from you, and they are open tomorrow...
Old Jun 29, 2006 | 10:43 PM
tyco's Avatar
Default Re: better handling (project_B18C1)
Go with my set up, Megan lower bottom front H-Bar, ITR Upper Front strut bar, Megan Lower rear tie bar, Megan X-Bar behind the seat, X-Bar over the spare tire bay. 23mm ITR sway bars, Tein Super streets, front cross member
Old Jun 29, 2006 | 10:47 PM
Sack Master's Avatar
Default Re: better handling (tyco)
It would be a good idea to fix your tweaked rear wheel first. That may make a world of difference right there. Along with nice suspension upgrades a good wheel and tire package will work wonders
Old Jun 29, 2006 | 11:00 PM
Default Re: better handling (Sack Master)
by fixing the camber?...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">It would be a good idea to fix your tweaked rear wheel first. That may make a world of difference right there. Along with nice suspension upgrades a good wheel and tire package will work wonders</TD></TR></TABLE>
Old Jun 30, 2006 | 12:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">by fixing the camber?...</TD></TR></TABLE>Yes
Old Jun 30, 2006 | 12:20 AM
integralactic's Avatar
get a set of good tires
Old Jun 30, 2006 | 07:00 AM
jweezy225's Avatar
Default Re: better handling (integralactic)
i say a thicker sway bar... I bought a suspension techniques sway bar/tie bar kit but I've heard good things about just a JDM itr rear sway bar and a subframe reinforcement kit
Old Jun 30, 2006 | 08:24 AM
yee SERIOUS's Avatar
205/50/15 tires in the front and 195/55/15 tires in the back. some mag (i think car and driver or something) said this.
but i would just do a rear sway bar upgrade which will be less than 200.
Old Jun 30, 2006 | 08:33 AM
Spectrum24x's Avatar
Default Re: (undercoverdc2)
Cant believe nobody has suggested bushins.. derr
What kind of springs you running? and Please Don't tell me you cut your stocks
Old Jun 30, 2006 | 08:35 AM
Dforce's Avatar
That's what she said!
Default Re: (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">Cant believe nobody has suggested bushins.. derr
What kind of springs you running? and Please Don't tell me you cut your stocks</TD></TR></TABLE>
or aftermarket springs with stock shocks
Old Jul 2, 2006 | 09:47 PM
Default Re: (Dforce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dforce &raquo;</TD></TR><TR><TD CLASS="quote">
or aftermarket springs with stock shocks </TD></TR></TABLE>
uuuh no name brand coil-overs and kyb's
so by fixing camber it will deffinetly get better stability?
Old Jul 2, 2006 | 09:48 PM
Default Re: (depeche_mode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by depeche_mode &raquo;</TD></TR><TR><TD CLASS="quote">
so by fixing camber it will deffinetly get better stability?</TD></TR></TABLE>
Im confused, if you have coilovers, why would you have kyb struts?
Old Jul 2, 2006 | 09:50 PM
Im confused, if you have coilovers, why would you have kyb struts?</TD></TR></TABLE>
yeah sorry, lowering springs
Sic_DA_Nine's Avatar
kyb shocks and no name adjustable coilover springs?
whats not to get?
Old Jul 2, 2006 | 09:51 PM
Default Re: (Sic_DC_FOE)
Ok, that makes more sense...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DC_FOE &raquo;</TD></TR><TR><TD CLASS="quote">
whats not to get?</TD></TR></TABLE>
He didnt say adjustable coilover springs...
Old Jul 2, 2006 | 09:53 PM
to the orginal post... unless your camber is really fawked it shouldnt affect your sharp turns too much.. in all honesty it might be your driving...
For the longest time i was dissapointed in my car b/c i couldnt make turns like my friend did in his hatchback when my suspension was similar to his.. after a few weeks i learned it was my driving, the way i was entering the corners and exiting.. my throttle techniques etc..
Old Jul 2, 2006 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">to the orginal post... unless your camber is really fawked it shouldnt affect your sharp turns too much.. in all honesty it might be your driving...
For the longest time i was dissapointed in my car b/c i couldnt make turns like my friend did in his hatchback when my suspension was similar to his.. after a few weeks i learned it was my driving, the way i was entering the corners and exiting.. my throttle techniques etc..</TD></TR></TABLE>
sounds interesting..please explain
Old Jul 2, 2006 | 10:21 PM
Kinda tough to explain but ill do my best...
basically whenever i was going into sharp right hand turns i would kinda just throw my car into the turn.... took me a while to realize you need to down shift and brake before you get to the turn, and hold a steady throttle thru the turn, as to keep it hugging the inside...
Does your car have a lot of body roll? what is it about your car that makes you feel like it cant take these sharp turns? does it feel like it slides away from you?
Old Jul 2, 2006 | 10:29 PM
well ive driven my firends cars and they all seem really stiff on the turns,...they have noticed the difference in my car also...it just seems my car is too heavy...it feels like its going to oversteer
Old Jul 2, 2006 | 10:30 PM
hey can lower control arms help?...
Hm, its a tough subject, someone would almost have to drive a car to be able to say what you need...
I'd say just start upgrading the cheaper stuff untill it gets to where you want it.
btw, DA or DC?
Old Jul 2, 2006 | 10:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by depeche_mode &raquo;</TD></TR><TR><TD CLASS="quote">hey can lower control arms help?...</TD></TR></TABLE>
I have stock, and my car is stiff enough.
trojan
11
Dec 13, 2010 09:23 AM
s2k_3.11
Feb 28, 2007 05:45 PM
Try2Live4God
Feb 23, 2005 06:41 AM
IntegraPrez
Oct 9, 2004 09:08 AM
