Can a 92-95 Si Head fit a 92 CX block?
Old Apr 17, 2002 | 02:53 PM
CivicHB_92's Avatar
Default Can a 92-95 Si Head fit a 92 CX block?
Can this be done?
Thanks
Old Apr 17, 2002 | 04:09 PM
JaeOne3345's Avatar
Default Re: Can a 92-95 Si Head fit a 92 CX block? (CivicHB_92)
yes but u might wanna change those pistons..the 92-95 cx block is an 8 valve motor..with only 2 valve reliefs on each piston...with the 16v head u might wanna invest in pistons that tolerate all 16 valves
[Modified by JaeOne3345, 1:09 AM 4/18/2002]
Old Apr 17, 2002 | 05:58 PM
CivicHB_92's Avatar
Default Re: Can a 92-95 Si Head fit a 92 CX block? (JaeOne3345)
can i use the stock pistons from the Si motor?
Old Apr 17, 2002 | 07:48 PM
flat-blk-HB's Avatar
yes you can use ythe pistons from the SI, you can also use the pistons from a DOHC ZC..i hear this will create more compersion?
Old Apr 18, 2002 | 01:50 PM
CivicHB_92's Avatar
Has anyone done this before? If so, how did it turn out? and anything you can tell me what to look for while doing it.
thanks
Project_EK
Feb 2, 2009 09:23 AM
bazookatooth
Apr 15, 2005 09:55 AM
jdmef9gsr
Feb 2, 2005 10:42 PM
y49crxsi
Sep 11, 2003 07:03 AM
