motor swap?
Old Jun 23, 2006 | 07:08 PM
hondachris1994's Avatar
Default motor swap?
I have a 94 hatch with a b16 OBD1. What do I need if I put a 98 type R motor in cause its OBD2 I believe? My mounts will work for that motor rt?
Old Jun 23, 2006 | 07:41 PM
savinGAShaulinAss's Avatar
Default Re: motor swap? (hondachris1994)
just reuse ur obd1 distributor on the type r motor and you should be good
Old Jun 23, 2006 | 07:50 PM
Default Re: motor swap? (savinGAShaulinAss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by savinGAShaulinAss &raquo;</TD></TR><TR><TD CLASS="quote">just reuse ur obd1 distributor on the type r motor and you should be good</TD></TR></TABLE> thats the only thing that has to b done to make that motor work on a OBD1 car?
Old Jun 23, 2006 | 08:05 PM
yup
Old Jun 28, 2006 | 08:51 AM
slow poke's Avatar
No, the sensors on the IM and injectors wont work either. Are you going to run an OBD1 ECU? If you are then you want to make sure you have an ITR map on it or the motor will not be running at its full potential.
Old Jun 28, 2006 | 04:36 PM
rcoolb2002's Avatar
Default Re: motor swap? (slow poke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">No, the sensors on the IM and injectors wont work either. Are you going to run an OBD1 ECU? If you are then you want to make sure you have an ITR map on it or the motor will not be running at its full potential.</TD></TR></TABLE>
The sensors and the injectors both work the same. The clips are different. ITR injectors have different clips and some are 290cc injectors.
Old Jun 29, 2006 | 08:01 AM
slow poke's Avatar
Default Re: motor swap? (rcoolb2002)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcoolb2002 &raquo;</TD></TR><TR><TD CLASS="quote">The sensors and the injectors both work the same. The clips are different. ITR injectors have different clips and some are 290cc injectors. </TD></TR></TABLE>
OBD1 and OBD2 injectors clips are different. Nothing special about the ITR clips.
streetcartuner
Mar 30, 2008 10:25 AM
pearl
Jun 28, 2005 10:57 PM
EKB18BPR3
Jun 11, 2004 05:58 PM
Civic Hx-T
May 3, 2004 03:40 PM
SPOONfdEK
May 27, 2003 06:32 PM
