Motor?????
Old Jun 23, 2006 | 06:02 PM
hondachris1994's Avatar
Default Motor?????
I have a 94 hatch with a b16 OBD1. What do I need if I put a 98 type R motor in cause its OBD2 I believe? My mounts will work for that motor rt?
Old Jun 23, 2006 | 07:58 PM
hatchi's Avatar
Default Re: Motor????? (hondachris1994)
your mounts will work for that motor, reuse the injectors, alternator, dist, mounts, shift linkage. everything is plug n play and you can remain obd1
Old Jun 23, 2006 | 08:02 PM
Default Re: Motor????? (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">your mounts will work for that motor, reuse the injectors, alternator, dist, mounts, shift linkage. everything is plug n play and you can remain obd1</TD></TR></TABLE>Good info
EduardoDC5
16
Jan 8, 2009 10:52 AM
palisoc05
May 24, 2008 07:42 AM
EGcivicBoy
12
Dec 25, 2003 12:40 PM
