Cleaning my engine
Old Apr 17, 2002 | 02:26 PM
LilDevil's Avatar
Default Cleaning my engine
I just bought some "Simple Green" so that I can try to clean up my engine a lil bit.. I was just gonna use a toothbrush with it but I also have a little wire brush. Will the wire brush scratch things up? I apologize if this is a stupid subject but was on here and thought I would ask.
Old Apr 17, 2002 | 02:30 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (LilDevil)
Make sure you have a fine bristil wire brush and use is only on the tranny and engine block as needed.
Old Apr 17, 2002 | 02:35 PM
FifthGearOnline's Avatar
Default Re: Cleaning my engine (mantic6t9)
what about that foamy engine bright ****....does it work?
Old Apr 17, 2002 | 02:37 PM
FEneguM's Avatar
This is how they do it in the "AUTOLAND"
Old Apr 17, 2002 | 02:51 PM
hondachick81's Avatar
Default Re: Cleaning my engine (real sleepy integra)
hahaha ...looks like he's peeing on it!!
....that'll get it clean!
Old Apr 17, 2002 | 02:54 PM
Yokohama's Avatar
I have noticed that if you use any kind of engine degreaser...if sprayed on anything polished it "stains" it...makes it look really bad...so I suggest covering any polished pieces you have or they might get ruined.
Old Apr 17, 2002 | 04:13 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (YokohamaSiR)
I've been using simple green to clean my engine for a year now and it had never stained a thing in my engine bay.
Old Apr 17, 2002 | 04:22 PM
navin's Avatar
my engine block is now like oxidized because i used the valvoline **** - anyone got a clue how to get the oxidiation out??
thanks
Old Apr 17, 2002 | 05:59 PM
hybrider's Avatar
Default Re: Cleaning my engine (navin)
wd-40
Old Apr 17, 2002 | 06:12 PM
HXMan's Avatar
WD-40...that could take a long time!
Old Apr 17, 2002 | 07:12 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (Mad HXMan)
Rinse the engine down with water, soak everything with simple green, let sit for a little bit, start cleaning, rinse off with water, make sure you got everything, dry what you can with a towel or whatever you use, start engine and take it for a spin around the block, let sit untill engine is dry and cool, spray the block and tranny with wd-40 to avoid corrosion you can also use armoral.
Old Apr 17, 2002 | 07:21 PM
supergreenNA1's Avatar
New User
brake cleaner
Old Apr 17, 2002 | 07:39 PM
Jonathan_ED3's Avatar
Default Re: Cleaning my engine (supergreenSol)
don't forget to cover up your distributor and intake so you don't ingest anything!
Old Apr 17, 2002 | 08:08 PM
Dr.Kimball's Avatar
Default Re: Cleaning my engine (hot_EF)
Ive never coverd my distributor when cleaning my engine bay. Throw a towl over the battery, stuff a sock in your throttle body and have at it.
Old Apr 17, 2002 | 08:14 PM
bryant's Avatar
Default Re: Cleaning my engine (Dr.Kimball)
make sure to go easy when spaying around the electrical. Dont want to knock anything loose
Old Apr 17, 2002 | 08:28 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (CR-X)
I don't use water pressure, i let the water run free out of the hose.
Old Apr 17, 2002 | 09:48 PM
ToneyTigre's Avatar
New User
really? sure its safe to just hose your engine down? do you need to cover anything?
Old Apr 17, 2002 | 11:01 PM
Dr.Kimball's Avatar
Default Re: Cleaning my engine (ToneyTigre)
It felt weird at first, but you dont hurt anything..
Old Apr 17, 2002 | 11:13 PM
Spike2's Avatar
Before Simple green...
After Simple Green and some motor gankin
Just be sure to not scrub too hard
Old Apr 18, 2002 | 12:42 AM
Charles B.'s Avatar
Default Re: Cleaning my engine (Bob Ross)
Pretty good before and after pics. I wish I did that when I did my swap.
Old Apr 18, 2002 | 04:29 AM
Default Re: Cleaning my engine (SuperDuperEG)
oh yeah... sweaky clean
Old Apr 18, 2002 | 05:19 AM
sol-man's Avatar
Simply Green dissolved your engine away?!?
Strong stuff
Old Apr 18, 2002 | 05:34 AM
brcivic411's Avatar
Default Re: Cleaning my engine (sol-man)
simple green is the 'all-in-one-clean-it-all' solution.
Old Apr 18, 2002 | 09:29 AM
12 oz.'s Avatar
Default Re: Cleaning my engine (brcivic411)
dont get any water in the dist, alt, starter...or your done...happy cleaning
k2GM
Engine Management and Tuning
Nov 9, 2010 04:12 PM
slimjimming6688
Dec 28, 2008 04:30 PM
truevietluv636
17
May 17, 2007 03:03 PM
NA JDM GSR
Feb 14, 2005 06:10 PM
DevinW
Aug 28, 2002 09:02 AM
