any recomendations on cleaning engine
so today i was cleaning all tthe crap off my engine and there still a lot of crap on it, oiled dirt n stuff, cant get it out. so far i only used castrole superclean and simple green with a wire brush. it kinda worked ok but still hella dirty and stil stuck on the block, i need some kind of other cleaning products that will melt the dirt away or make it easyer to scrub everything off. just wanna know the other products that may work better
Re: any recomendations on cleaning engine
well ive always used the engine degreaser or just regular degreaser and sprayed it all over engine then rinsed it off with a hose. some ppl say its bad but ive been doing it for years... u can cover ur batt and alt if it worries u. dont pressure spray it as that might bust something loose or force water in somewhere, just like use the hose without a head or on mist mode.
and dont do it while ur engine is hot as it might warp/crack something... warm is ok.
Seagull Management
Lawson orange degreaser works well (I forget the exact name, but its made by lawson, I have no idea where you can get it either) engine brite is basically just diesel in an areosol can. Brake clean also works well.
