Brake drum won't fit new brake shoes
Old Jun 23, 2006 | 04:17 PM
Tb0y's Avatar
Super Duper Senior Member
Default Brake drum won't fit new brake shoes
I bought the Raybestos brake shoes and replaced the old shoes in the rear for my 88 SI. But now the drums won't go in anymore because the brake shoes are in the way. What do I need to do to get the shoes out of the way or do I need to resurface the drums?
Old Jun 23, 2006 | 05:57 PM
24TEN's Avatar
PHANTOM MENACE
this may be a dumb question, but is your ebrake down?
Old Jun 23, 2006 | 06:03 PM
lsvtecSIrex's Avatar
isnt this caused by the new shoes being thicker? u need to loose some brake fluid i think. i dunno, just guessing
Old Jun 23, 2006 | 06:11 PM
aXhatch's Avatar
Default Re: (lsvtecSIrex)
Two thoughts.
1: ebrake, cuz of the rear, maybe ur ebrake is on.
2: Can you adjust the star nut to bring the shoes closer together by any chance? SOMETIMES they will be adjusted for the more worn pads, and installing the news ones now the drums dont fit.. Id try those first.
Old Jun 23, 2006 | 10:08 PM
eltigre's Avatar
Default Re: (aXhatch)
it cost bout the same to resurface..
but could be e-brake and make sure the shoes are nice and snug
Old Jun 24, 2006 | 12:35 AM
Tb0y's Avatar
Default Re: (eltigre)
The ebrake was down the whole time during the change. I finally got the drums on by adjusting gear to bring the shoes closer and used some force to push the drums in. Thanks anyways for the help
Old Jun 24, 2006 | 04:26 AM
aXhatch's Avatar
Default Re: (cr-x siR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aXhatch &raquo;</TD></TR><TR><TD CLASS="quote">
2: Can you adjust the star nut to bring the shoes closer together by any chance? SOMETIMES they will be adjusted for the more worn pads, and installing the news ones now the drums dont fit.. Id try those first.</TD></TR></TABLE>
you did what I tried to explain !
and it worked! nice, how them new shoes treating ya?
Old Jun 24, 2006 | 04:40 AM
crazi-85crx's Avatar
Where is this "star nut"? I've been having the same problem.
Old Jun 24, 2006 | 07:04 AM
Chiovnidca's Avatar
Default Re: Brake drum won't fit new brake shoes (cr-x siR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x siR &raquo;</TD></TR><TR><TD CLASS="quote">I bought the Raybestos brake shoes and replaced the old shoes in the rear for my 88 SI. But now the drums won't go in anymore because the brake shoes are in the way. What do I need to do to get the shoes out of the way or do I need to resurface the drums?</TD></TR></TABLE>
You may have to back off the adjusting nut at the e-brake handle.
bottino
Honda Civic (2001 - 2005)
Jan 16, 2007 09:23 PM
Extremity
Apr 8, 2006 04:59 PM
dip-set
Jul 28, 2004 10:54 AM
nvmyskills
Mar 30, 2004 06:50 PM
udm_motorsport
Mar 10, 2004 06:17 AM
