Tuning ??????
Old Jun 23, 2006 | 03:24 PM
hondachris1994's Avatar
Default Tuning ??????
I have a 94 cx with a b16 with Type R mani, JE 11.1 pistons,head shaved all the way, 1mm oversized valves, upgraded valvetrain, MSD dizzy with coil, stage 2 cams, buddyclub cam gears,chipped p28 ecu, motor rebuilt 3 months ago...The car is untuned... Will a street tune give my car more power and is it necissary for a dyno tune, and do I have to buy a wideband to get the car tuned? Just curious never had a car tuned before and want to no the advantages
Old Jun 23, 2006 | 05:13 PM
b18sihatch's Avatar
Default Re: Tuning ?????? (hondachris1994)
street tuning can give you good power... and can set you up for dyno tune, however street tune with take your application only so far and will look towards a dyno tune to get some good power out of it, esp with the camshafts and gears, adjusting the timing and whatnot can give you better advantages
Old Jun 23, 2006 | 07:07 PM
Default Re: Tuning ?????? (b18sihatch)
so a street tune mainly consists of your A/F ratio correct?
Old Jun 23, 2006 | 09:11 PM
SuzukaBlueAP2's Avatar
If you know what you're doing a street tune can help make some more power and make your engine a little healthier.
You state that you have a chipped P28. What is it chipped with? Do you have any method of adjusting ignition timing? Add/remove fuel? Do you have the cam gears adjusted from stock cam position?
If this is your first project take it to someone and have it tuned on a dyno. While they are tuning ask them if you can watch because you want to learn about it.
Old Jun 23, 2006 | 09:33 PM
98vtec's Avatar
moderator emeritus
Default Re: Tuning ?????? (SuzukaBlueAP2)
i street tune will put the engine at safe parameters. A dyno will help you dial in the power.
Old Jun 24, 2006 | 10:29 AM
Default Re: Tuning ?????? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">i street tune will put the engine at safe parameters. A dyno will help you dial in the power.</TD></TR></TABLE> thanx
Old Jun 24, 2006 | 12:40 PM
On a basic street tune do they play with the cam gears at all?
Old Jun 24, 2006 | 12:45 PM
98vtec's Avatar
moderator emeritus
not normally. Thats a dyno thing.
Old Jun 24, 2006 | 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">not normally. Thats a dyno thing.</TD></TR></TABLE>thats what I figured just wanted to make sure
Old Jun 25, 2006 | 01:27 AM
mtber's Avatar
negusjuda
92
Oct 30, 2011 02:24 PM
starcrossed010
Mar 18, 2007 08:33 PM
type B16
Aug 19, 2006 07:42 AM
hondachris1994
14
Jun 25, 2006 01:25 AM
2000fbp
Feb 7, 2004 08:16 AM
