Turbo Timer Install PROBLEM in a DC2 **SEARCHED***
Old Jun 23, 2006 | 02:51 PM
beseman's Avatar
Default Turbo Timer Install PROBLEM in a DC2 **SEARCHED***
Im sweating like ******* crazy sitting out in my 97 teg tryin to get this POS to work.
got it grounded and have the harness hooked up to the only 2 connectors i could find under there. For this harness tho that i bought separately, there is a random white wire sticking out with some sort of connector on the end....does this need to be plugged into something, bc there sure as hell isnt an instruction manual with this harness. Pleasssse help me
here is what i am talkin about, its kina hard to see but its right under that white connector
Old Jun 23, 2006 | 03:31 PM
Shmaa's Avatar
Default Re: Turbo Timer Install PROBLEM in a DC2 **SEARCHED*** (beseman)
I didn't use a harness for mine so I cant really tell since the colors are different, but I would say it is either not used or it goes to the e-brake to shut the car off if the brake is disengaged.
Old Jun 23, 2006 | 03:47 PM
beseman's Avatar
Default Re: Turbo Timer Install PROBLEM in a DC2 **SEARCHED*** (Shmaa)
theres another wire coming out of the relay of the timer for that already
Also, when i try to put it on a ground, it turns on for like half a second, then turns off and doesnt come back on unless i disconnect the ground and wait for a while then try it again, and its on a good ground, ive checked in a million times
Old Jun 23, 2006 | 04:04 PM
beseman's Avatar
when i try to put it on a ground, it turns on for like half a second, then turns off and doesnt come back on unless i disconnect the ground and wait for a while then try it again, and its on a good ground, ive checked in a million times.
how do i get it to stay on???????
PatrickGSR94
Audio / Security / Video
13
Aug 30, 2006 04:41 AM
beseman
Aug 7, 2006 05:35 PM
Racermech
Jun 18, 2005 07:34 AM
dabrown
Aug 7, 2003 05:56 PM
