MPH doesnt work
Old Jun 23, 2006 | 02:48 PM
Boostage's Avatar
Default MPH doesnt work
I put my cluster in my other car and it works, so the cluster is good, I took the speed sensor out and put it in my other car and it works, so the vss is good, so what else could it be? 94 EX with b16/turbo.
Old Jun 23, 2006 | 04:03 PM
WillieB's Avatar
Default Re: MPH doesnt work (Boostage)
I went through the same crap. The connector from my wiring harness was bad. The middle pin had alittle rust.
Old Jun 23, 2006 | 04:12 PM
Boostage's Avatar
Default Re: MPH doesnt work (WillieB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillieB &raquo;</TD></TR><TR><TD CLASS="quote">I went through the same crap. The connector from my wiring harness was bad. The middle pin had alittle rust.</TD></TR></TABLE>
The yellow or green one? I assume one of those conrols the odometer and the other controlls the speedo.
Old Jun 23, 2006 | 05:03 PM
Boostage's Avatar
could this be a problem with teh harness? I mean it seems like the cluster is just not getting the signal outputs from teh VSS. so Im guessing it might be the harness or some kind of grounding issue. has anyone ha this problem after a swap?
Old Jun 23, 2006 | 06:16 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Boostage)
Your car is too fast. Honestly: DOHC VTEC <u>AND</u> turbo!? Are you insane? Your car probably travels beyond the realm of conventional speeds and, thus, your speedometer can't possibly be of help to you. It must have killed itself in a fit of depressive worthlessness.
Old Jun 23, 2006 | 08:47 PM
Sleepy_Red_hatch's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Your car is too fast. Honestly: DOHC VTEC <u>AND</u> turbo!? Are you insane? Your car probably travels beyond the realm of conventional speeds and, thus, your speedometer can't possibly be of help to you. It must have killed itself in a fit of depressive worthlessness.</TD></TR></TABLE>
arch, your all over the place tonight
Old Jun 26, 2006 | 05:05 PM
Boostage's Avatar
Help
Old Jun 26, 2006 | 06:00 PM
jdmsiR20's Avatar
at what point was the MPH working?
what parts were in that had it going fine? go back to that.
Old Jun 26, 2006 | 07:41 PM
Boostage's Avatar
Default Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">at what point was the MPH working?
what parts were in that had it going fine? go back to that.</TD></TR></TABLE>
Worked fine when Ihad teh stock sohc in it. the new b16,turbo, with electronics (turbo timer,guages boost controller) were all installed at the same time, and after the swap. the MPH didnt work. The clsuter is good, the VSS is good, the fuses look good. so does that leaves the harness?
hondagurl00
Nov 6, 2011 01:01 PM
daname
Aug 24, 2008 01:00 PM
ViSiONxBoY
Jan 14, 2008 04:03 PM
civicEXtreme
Dec 15, 2007 03:10 PM
