What b-series tranny
Old Jun 23, 2006 | 02:40 PM
bamboosted's Avatar
Default What b-series tranny
What tranny do you guys use or prefer for boost? looking for 450+ Whp
Or would you re-gear a tranny?
Old Jun 23, 2006 | 03:19 PM
I Have an STD's Avatar
wrenchin'
Default Re: What b-series tranny (bamboosted)
i love my B16 tranny on my LS motor
Old Jun 23, 2006 | 03:39 PM
scB20teg's Avatar
Default Re: What b-series tranny (I Have an STD)
This poll is kinda silly imo. The B16/ITR has the same gearing, so there shouldn't be 2 seperate categories for them. Also a custom geared transmission to fit your specific setup would always work better than a stock honda transmission, since everybody's setup isn't the same. This thread will probably just end up in a BS match.
Old Jun 23, 2006 | 05:25 PM
komat's Avatar
Default Re: What b-series tranny (scB20teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scB20teg &raquo;</TD></TR><TR><TD CLASS="quote">This poll is kinda silly imo. The B16/ITR has the same gearing, so there shouldn't be 2 seperate categories for them. Also a custom geared transmission to fit your specific setup would always work better than a stock honda transmission, since everybody's setup isn't the same. This thread will probably just end up in a BS match. </TD></TR></TABLE>
depending on the year of the type r. they have a higher final drive.
im using a b16 tranny with 420hp/312tq
Old Jun 23, 2006 | 05:37 PM
non-VTEC's Avatar
GSR trans
Old Jun 24, 2006 | 05:48 AM
bamboosted's Avatar
Default Re: What b-series tranny (komat)
how do y6ou like the b16 tranny? i have one just haven't installed it, some people say they don't like it with the high horsepower. What gear are you in by the end of the track?
Old Jun 24, 2006 | 05:56 AM
hotimportcrx's Avatar
Ive had b16 and gsr and i like the b16 better.
Old Jun 24, 2006 | 06:23 AM
Boostage's Avatar
I like my LS tranny.
Old Jun 24, 2006 | 06:52 AM
KeyserSoze's Avatar
I agree for the most part. It is a preference. Here is what Jeff Evans said a while back....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote"> Gear ratios are merely a way to trade torque for rpm. With a higher numerical gear ratio, you are putting more rpm at the wheel. With closer gear ratios, you are able to stay at a higher rpm in between shift points. Something like the LS transmissions are suited more towards the broad torque curve/low reving LS engine. It keeps you in the peak torque area in between shifts. The ITR/SI/GSR transmissions keep the rpm's built up in between shifts, to stay in the more peaky powerband.
Having said that, for the track the itr/si tranny is the best hands down. Most high whp turbo engines are operating between 5.5-9k, and having their shift points in between. In combination with a tall slick size (24.5"+), and the high shift point (8.5-9k), you are able to keep the engine operating within the optimum torque curve.
With the LS transmission, between shifts it would possibly drop you out of the optimal powerband and therefore make you slower. Gearing simply put allows you to stay in the powerband of your engine in between shifts.
The myth that you stay in gear longer with the LS transmission makes you faster is purely false. Think about that statement for a second. Acceleration is the measure of velocity over a unit time. Watching the rpms climb on the tach during a 3rd/4th gear pull, they would be climbing slower than with the si/itr tranny. Looking at the definition of acceleration as a measure of velocity over a unit time, the engine would be getting to the same velocity over a slower time lapse. This would yield slower acceleration, and simply put make you slower.
Having said that, the gsr transmission is probably the best balance of a street/strip transmission. The gearing is a little less aggressive as the itr/si transmissions, which will yield a little more traction. For all out acceleration si/itr tranny wins hands down. For a slower car, go with the LS transmission.
Now I don't know if he still thinks this way, but that was his reasoning at that time. I have also heard some good justifications for using an ls tranny. There are a lot of really fast cars that use all of these (ls, gsr, b16/itr) and have very good results. Try a couple out and pick which one you like best....
Edit: I am running a gsr tranny in my car.
Modified by KeyserSoze at 4:41 PM 6/24/2006
Old Jun 24, 2006 | 11:10 AM
96 GSR-T's Avatar
Default Re: What b-series tranny (KeyserSoze)
I have an LS on my GSR and I HATE IT, the damn car goes almost 80 in 2nd gear around 91-9200 rpm. You have to shift it that high to get the RPM's to stay over 6k. If you shift at 8k, the car bogs out/falls on its face and falls out of the power band, the only beneficial thing is I can cruise @ 80mph at 3400rpm
Old Jun 24, 2006 | 11:45 AM
Dc4turbo408's Avatar
Default Re: What b-series tranny (96 GSR-T)
i have a ls tranny in a ls.. Love it..
Old Jun 24, 2006 | 11:52 AM
komat's Avatar
Default Re: What b-series tranny (Dc4turbo408)
i love the b16 around the city. but when it comes in the highway. thats another story...
Old Jun 24, 2006 | 12:06 PM
Cimburke23's Avatar
i love my gsr, but have recently gone to a gsr trans w/ LS final drive, for a little better traction hopefully. depending on what slick size or tire size, you could basically change ur FD by changing the tire size
Old Jun 24, 2006 | 02:51 PM
bamboosted's Avatar
Default Re: What b-series tranny (Cimburke23)
thanks on all the post keep them coming.. for all you ls tranny users what motor are you running and what is your whp and rev limiter at ?
Old Jun 24, 2006 | 03:33 PM
96 GSR-T's Avatar
I am running a B18C, I was at 300whp before..... stock head so it was 8k
Same engine, fully built head, prob double the hp..... awaiting dyno but I will prob shift in between 9000 or 9500 depending on my torque curve etc. I will be ditching the LS in favor of an ITR gearset or GSR with the LS 5th for the cruise, i figure that switch right there will be worth .5 sec in the quarter over the LS in my car.
Old Jun 25, 2006 | 02:02 PM
bamboosted's Avatar
Old Jun 25, 2006 | 02:29 PM
boostfeen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">I have an LS on my GSR and I HATE IT, the damn car goes almost 80 in 2nd gear around 91-9200 rpm. You have to shift it that high to get the RPM's to stay over 6k. If you shift at 8k, the car bogs out/falls on its face and falls out of the power band, the only beneficial thing is I can cruise @ 80mph at 3400rpm</TD></TR></TABLE>
IMO- take the LS fith out and use the rest as a door stop.
the b16 and Gsr are very similar but not exactly the same.
...B16 with an ls fith and Quife LSD and your good
Old Jun 25, 2006 | 06:04 PM
bamboosted's Avatar
Default Re: What b-series tranny (boostfeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfeen &raquo;</TD></TR><TR><TD CLASS="quote"> IMO- take the LS fith out and use the rest as a door stop.
...B16 with an ls fith and Quife LSD and your good </TD></TR></TABLE>
Thank you you seem to be alot of help to me ..
Old Jun 25, 2006 | 06:33 PM
swappedcx's Avatar
i have a ls motor now with the GSR trans, and pretty much hate it.
Im CONSTANTLY shifting gears, even on back roads im in 4th or 5th gear. (i usually hit 5th at about 45mph) which i think is shifting out of 4th at like 3k or a bit less.
before i go ahead and slap my ACT clutch in im searching for a good LS tranny to ditch for the GSR.
Old Jun 25, 2006 | 07:09 PM
DaveF's Avatar
Default Re: What b-series tranny (swappedcx)
i have 2 ls gearsets. PM me if interested..
send all your b16 hydro trans to me
Old Jun 25, 2006 | 07:20 PM
vaporboy12's Avatar
Default Re: What b-series tranny (dturbocivic)
i need some too dave hehe
itr590
Nov 5, 2007 10:08 AM
PJ
Northeast (Sales)
Oct 11, 2007 11:22 PM
jfrase06
13
May 17, 2007 09:00 PM
ReggieGrip
Apr 29, 2006 09:25 AM
kemil
14
Dec 1, 2005 04:15 PM
