BOSCH universial o2 sensor HELP!! 96 accord chasis with 93 jdm h22a
Old Jun 23, 2006 | 12:26 PM
duceducecord's Avatar
Default BOSCH universial o2 sensor HELP!! 96 accord chasis with 93 jdm h22a
i recently bought a new Bosch Universal o2 sensor for my car which is a 96 accord with a 93 jdm h22a motoor in it. im having problems trying to figure out which wire is which on the universal o2 sensor it has 2 white wires and one grey one n a black one... i am running a 96 honda accord engine wiring harness with a jdm p13 ECU HELP! P.S its the primary o2 sensor
Old Jun 23, 2006 | 12:43 PM
Eddiebx's Avatar
read the instructions that comes with it, it tells u what each wire does.
Old Jun 23, 2006 | 03:39 PM
prelude1897's Avatar
Default Re: (Eddiebx)
you should've bought some O2 sensors from http://www.sparkplugs.com they're OE spec and cheaper
Old Jun 24, 2006 | 10:33 AM
djbrandonr's Avatar
Default Re: BOSCH universial o2 sensor HELP!! 96 accord chasis with 93 jdm h22a (duceducecord)
the instructions dont help. The OEM harness will have 4 wires 2 w/ the same color, so wire those to the whites, and I just guessed on the last 2. Its a 50/50 shot then. If the car runs good on the first fire up you got it. If not swap those last 2 wires and you should be in business.
Old Jun 24, 2006 | 11:48 PM
Default Re: BOSCH universial o2 sensor HELP!! 96 accord chasis with 93 jdm h22a (djbrandonr)
so like sense the Bosch o2 sensor has 2 white wires and i think my OE harness has some colorful wires but i think there are 2 wires are the same but im not sure...n e ways those 2 wires i can just hook stright up or is there a certin wire i have to hook it up to for example....the left white wire has to go on the right side of the OE harness black wire and the right white wire from the Bosch has to go on the left side to the OE harness black wire....i was trying to reach the wiring diagram and the instructions that came with the o2 sensor but it doesnt seem to help.each wire has a certin place to go but i just dont know which one is which... as of now i no my OE wiring hardness has like green, red and some other colors... but i'll try ur way first n see were that goes if it doesnt work i'll prolly go to sparkplugs.com and buy the OE one
Old Jun 25, 2006 | 12:19 AM
djbrandonr's Avatar
yeah there were 2 wires the same color on the OE harness.
Old Jun 25, 2006 | 07:14 PM
n on the Bosch o2 sensor i can just randomly hook up those to wires from the Bosch to the OE harness or do i have to swap those around to
Old Jun 26, 2006 | 08:12 PM
djbrandonr's Avatar
i think the 2 same colored wires are grounds. 1 is for input and believe the other is cause its a heated o2 sensor IIRC
Old Jun 26, 2006 | 11:33 PM
alrite kool i'll hook it up like u said n see wat happens thanks for the hlep i'll post up again with the status of my project thanks !
Old Jun 26, 2006 | 11:38 PM
djbrandonr's Avatar
word, Im from SD myself. Broncos!!! Boooooooootch yeah yeah 858 in da house...lol
Old Jun 29, 2006 | 11:21 PM
for real.r u the one with that red prelude? im in 619
Old Jul 1, 2006 | 08:30 AM
djbrandonr's Avatar
nah, Im still livin in CO bein a ski/golf bum.
Old Jul 1, 2006 | 09:28 AM
o koo
lysedi
Oct 12, 2016 07:14 PM
808DA
Jun 1, 2011 09:08 AM
beasly
Jul 9, 2004 08:34 PM
