code 9
Old Jun 23, 2006 | 12:16 PM
2poor2tune's Avatar
Default code 9
#1 cylinder position. what do i do to fix this
Old Jun 23, 2006 | 12:28 PM
Suck my DX's Avatar
Default Re: code 9 (2poor2tune)
if im not mistaken u need a new dizzy...
Old Jun 23, 2006 | 01:07 PM
2poor2tune's Avatar
yeah i replaced it with a known good one and the code went away so now its just getting the car started still. no codes spark/fuel/ did compression check and out of ideas. i hate this. i just want to drive my car
Old Jun 23, 2006 | 01:38 PM
RCautoworks's Avatar
We have an faq section you know
Code 9 - No. 1 Cylinder Position Sensor
It's the third sensor in the dist., and it detects the position of the No. 1 Cylinder, as the base for the Sequential Injection. It can also be located on the camshaft of DOHC engines.
CYP sensor is mounted on the exhaust cam on the ZC.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up to 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing by itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Back
Tippyman
Mar 10, 2006 06:03 PM
JinksItR
Feb 13, 2006 02:24 PM
jccrxtuner916
Feb 12, 2006 10:32 PM
1991dxhatch
Apr 8, 2004 04:59 PM
RaIn
Apr 20, 2003 08:05 PM
