anyone install obd2 thorottle onto obd1
Old Jun 23, 2006 | 09:54 AM
go2sleep's Avatar
Default anyone install obd2 thorottle onto obd1
im pretty sure some of you must have swapped the obd2 throttle body in place of your obd1. i was goin to do so and i came across the vaccum line that the obd2 tb doesnt have. someone said to hook the carbon canister vac line into my intake arm, but i have no other lines that come out of the intake arm. could anyone shed some light.
Old Jun 23, 2006 | 12:31 PM
go2sleep's Avatar
Default Re: anyone install obd2 thorottle onto obd1 (go2sleep)
^^ up before work
Old Jun 23, 2006 | 06:07 PM
BlueCrxNC's Avatar
Just tee into an existing vacuum line. I have several things tee'd into the only standard size vacuum nipple on the JDM D15B VTEC intake manifold. (FPR, Purge Valve, etc)
Old Jun 23, 2006 | 06:12 PM
Whig-it's Avatar
On my ls, i don't even use that tube, i have it blocked off. i think it's for the charcol canster, not postive tho
Old Jun 23, 2006 | 06:15 PM
BlueCrxNC's Avatar
Default Re: (Whig-it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whig-it &raquo;</TD></TR><TR><TD CLASS="quote">On my ls, i don't even use that tube, i have it blocked off. i think it's for the charcol canster, not postive tho</TD></TR></TABLE>
That is correct.
Old Jun 23, 2006 | 10:20 PM
go2sleep's Avatar
i was thinking about just capping it at the canister, but i want to pass BAR. i guess i'll just have to clean out the obd1 throttle body....
teggything
Jan 16, 2009 11:08 PM
SH
Mar 25, 2008 08:12 PM
go2sleep
Aug 2, 2005 08:24 AM
Comp97GSR
May 16, 2004 08:10 AM
