99 SI - Idles where it wants and Stalls?
I have been having a problem with my 1999 SI since I bought it, It idles weird, not a surge but more of a low idle. Sometimes when I come to a light and put in it nuetral it will stall. Then this is the wierd thing, when I restart it, for a second it acts like its cold, like it idles @ 2k for maybe 2-3 seconds, then gets to idle normal.
Anyone have any idead about this? The only CEL I ever got since I owned the car was a p0172 & p0170 (Bank 1 Sensor 1) (Fuel Trim Malfunction). Dont know if these have anything to so w/ my problem but I reset the ecu after that and its never come back since.
Mods are:
CROWER 401'S
AEM V2
CAT BACK EXHAUST
BLOX IM
FPR/GAUGE
AEM PULLEYS
Thanks in Adv
Mods are:
CROWER 401'S
AEM V2
CAT BACK EXHAUST
BLOX IM
FPR/GAUGE
AEM PULLEYS
Thanks in Adv
try raising the idle, the theres a little screw on top of the throttle body it may have a rubber cap or some gray waxy crap on it, turn it counter clockwise a little at a time see if it helps, also when was the last time you did a tune up, plugs, cap, rotor etc.
Plugs.wires cap and rotor are ALL BRAND NEW. I tried adjusting the idle air screw but it seems like it helps while the car is sitting there but when Im driving is when I getting this problem. Like @ a lite it will stall or idle @ like 2-300.
Could I just need a tune really bad? My chipped ecu from phearable is on its way, ill be obd1 once that gets here also.
Dont know where else to look, ive tried unpluggin the iacv and map then pluggin em back in, resettin the ecu, but doesnt help!!!!!!
Yup, I thought that was it too and when I put my Hondata gasket w/ Blox Manifold on it looked like it mighta been a LITTLE bit dirty so I hit it w/ BrakeKleen. Didnt help at all. Im so confused!
VersedCivic
May 19, 2014 05:23 PM
dchampn
40
Feb 11, 2013 02:36 PM
PwrdByVtec_EM1
18
Oct 1, 2011 08:03 AM
