Question about buying a Honda block
Old Jun 23, 2006 | 03:38 AM
7rrivera7's Avatar
Default Question about buying a Honda block
I'm looking to buy a B18 block with GE sleeves already installed but the block is bare:
http://cgi.ebay.com/ebaymotors...wItem
I've been told that when you buy a block, you should get it with the original main caps, otherwise you will have problems with the crank.
Is this true? I have a GSR in my CRX right now but I don't really want to pull it and send it out to get sleeved because of the downtime.
Let me know if buying bare blocks is ok
Old Jun 23, 2006 | 10:24 AM
rmcdaniels's Avatar
Default Re: Question about buying a Honda block (7rrivera7)
You need the original main caps, otherwise your main bearing clearances will be fucked. Fucked main bearing clearances can be fixed if you can find another set of main caps, but it's a hassle and you wind up dong something like getting custom-made main bearings or having your pistons out of their holes and getting a custom-made head gasket to compensate. I've done it successfully before, but I didn't have to pay anything for the sleeved block, and it was still an expensive hassle. If I had to pay >1K for the block, then it wouldn't be worth it.
Old Jun 23, 2006 | 12:14 PM
BuddhaSiR's Avatar
Default Re: Question about buying a Honda block (rmcdaniels)
You should ask the seller if the main caps are included. doesn't really say. bare block could mean no crank, no rods, no pistons. If no main caps, you will need to have the block line honed and the crank machined.
Icon_Ed6
11
Jul 10, 2011 05:05 AM
krick182
Oct 2, 2010 12:30 AM
x91crxsix
Jul 21, 2006 08:59 AM
Tex Blackwell
Feb 2, 2005 04:20 AM
Jared
Jun 24, 2001 09:53 AM
