D15 mini me turbo?
Old Jun 23, 2006 | 01:37 AM
Clean88crx's Avatar
Default D15 mini me turbo?
Just wondering, has any body done this.......if so please let me know what im getting into, im on a super tight budget and dont really need to spend mad loot for high horsepower......just trying to do a quick build for experience and fun.
I have an 88DX so Im obviously using the d15, but unclear of which Vtec head to use or are they the same if they are are SOHC, if not which is better? Also could I upgrade my stock ECU to an SI ECU (PM6)?
I have searched all over tryin to find something about this little project and I cant find anything.
I found full turbo kits on ebay for the d15, but not sure if I should trust the manufacturers. And like i said I want to do the mini me on top of it.
for example heres a link:
http://cgi.ebay.com/ebaymotors...ZWDVW
Only reply to this post if you know what your talking about , i dont need a lecture on why I shouldnt do this. Just facts on what I need to complete this.
thanx in advance.
Modified by Clean88crx at 3:03 AM 6/23/2006
Old Jun 23, 2006 | 02:04 AM
crxnj's Avatar
Default Re: D15 mini me turbo? (Clean88crx)
Thats the type of company that you want to stay away from..90% of they're products are garbage and the customer service sucks....SS auto chrome,stone racing,xs power are all the same thing,,,,they make some decent products...but their manifolds,turbos,and wastegates are iffy....
if you dont have that much money why not just turbo the D15b2 motor? forget about mini-me setup...
Old Jun 26, 2006 | 11:37 PM
Clean88crx's Avatar
Default Re: D15 mini me turbo? (Mr.speaker)
Well, the Vtec head will give me a gain of about 20 HP, plus the turbo. So if anybody knows a good turbo that wont put too much power for my little a$$ block!?? .....lemme know.
Old Jun 26, 2006 | 11:39 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
forget about VTEC head, dealing with timing with mini-mes is a bitch in NA form, let alone boosted.
use a T25 or 14B for your D15.
Old Jul 19, 2006 | 08:18 PM
RockinDa_
yah i agree plus i highly dought that there going to be a 20 horsepower increase just with a stock vtec head.. Try going to <U>Homemadeturbo.com </U>they helped me alot. Im going through the same thing you are right now i have a manifold, intercooler,turbo still trying to get other parts just be patient cause i put this project aside sooo many times so just stick to your plan..and visit this web site..
Old Sep 25, 2010 | 06:45 PM
HondaSPEC99's Avatar
Post Re: D15 mini me turbo?
I am doing the same thing but I have the 95 Civic hatch DX with the D15b7 and swapping heads for a nicely ported Z6 with y8 IM. I am boosting with Garrett and pushing upwards to 10psi
The parts I needed or though helped was-
- WALBRO 255LPH Pump
- 450cc DSM blu top injectors
- y8 IM complete
- .030 Metal head gasket
- The Vitara 75mm D series Pistons/ rings 8.5:1cr
- Rods and rod bearing by ACL (bearings)
- ARP Studs are a must
- P28 ECU (virgin to start)
- OBD1 Vtec Dizzy off the Z6
- Turbo kit (Garrett i used)
- New Water pump is highly recommended
- HIGHLY RECOMMEND TUNING FOR THE P28 Vtec (use Neptune)
- XTD Stage 3 Clutch/ flywheel if you want... ($cheap$)
The project has just begun... I will be hopefully pumping out 220-230whp
(Its my DD not a race car)
Old Oct 2, 2010 | 10:50 AM
kin6521's Avatar
i have some of these parts that u r looking for ...
-y8 IM complete
-OBD1 Vtec Dizzy off the Z6(brand new never used)
Old Jul 24, 2013 | 09:01 AM
boosted panda's Avatar
- y8 IM complete
i kno im late but i wanna build and boost my d15z6 mini me what rods did u use? im having a hard time finding some. thanx in advance
Old Jul 25, 2013 | 07:03 AM
Dark_Teg's Avatar
A properly sized turbo will be capable of making much more HP than your internals can handle. Any money spent on a better head, porting, intake manifold etc... would be a total waste of money.
Jay_Mills
Mar 31, 2012 04:57 AM
shootababe
Aug 6, 2009 12:00 PM
nickjgriff
Apr 13, 2009 09:00 AM
jonnycivic
Feb 22, 2007 06:42 PM
91civichatch
Jan 15, 2004 12:16 PM
