Crx Si Seats into Hatch: Swap pans or Weld rails?
Old Jun 22, 2006 | 10:30 PM
Nisif's Avatar
Default Crx Si Seats into Hatch: Swap pans or Weld rails?
So far I've found that my 91 Hatch Dx seat pans are roughly 2 inches wider compared to the Crx Si seat pans and that the linkage from the bottom cushion to the top (aka seat back cushion) is slightly different between the two types of seats. For those that have accomplished this, did you:
A) Retain the crx seat pans and hardware and weld the civic rails to them, or...
B) Fitted the wider civic seat pans, rails and hardware to the crx seats
Any input or links of "specific" write-ups would be great, I only ran across one slightly informative post which mentioned about a past write-up but I couldn't find it
Here's the link: https://honda-tech.com/zerothread?id=1552614
Old Jun 23, 2006 | 07:40 AM
89shithatch's Avatar
Default Re: Crx Si Seats into Hatch: Swap pans or Weld rails? (Nisif)
1. jbweld them in
2.swap the seat pans
3.Only use the two bolts that will fit in (Dont do this)
4.Use the holes that fit, and for the other ones that dont fit, cut it out and weld a piece of metal in there, drill a hole where it will fit and call it a day. Basically making a bracket.
Old Jun 23, 2006 | 08:13 AM
Nisif's Avatar
bump, hopefully I get pics up here to clarify
Old Jun 23, 2006 | 08:48 AM
Nisif's Avatar
Default Re: Crx Si Seats into Hatch: Swap pans or Weld rails? (89shithatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89shithatch &raquo;</TD></TR><TR><TD CLASS="quote">1. jbweld them in
4.Use the holes that fit, and for the other ones that dont fit, cut it out and weld a piece of metal in there, drill a hole where it will fit and call it a day. Basically making a bracket.</TD></TR></TABLE>
Hmm, I didn't consider the first option , I'm thinking that swapping the pans would be the best bet if it works.
Old Jun 23, 2006 | 09:18 AM
G0crxG0's Avatar
Hope you getem in there man!
Hey did you want me to upload your video, or were you gonna?
I noticed there's a CRX/Civic Video Thread stickied to the top of our forum, so you/me could post it there w/o problems
Old Jun 23, 2006 | 10:07 AM
91civicEX's Avatar
dont jb weld your fawking seats man. if you ever get in a accident or even brake too hard theyre comin off. u need to make custom brakets. or find some hatch si seats
Old Jun 23, 2006 | 07:00 PM
yea, i got eg seats in my ef. I just bolted the two front brackets in (they fit) and for the rears i just cut out the old bracket and weld a square piece of metal in. Then drill a hole in the metal piece where you need to. Also, if you jb weld them correctly, your seats will stay put.
Old Jun 23, 2006 | 07:13 PM
crxblues's Avatar
Default Re: (89shithatch)
swap the pans its not that hard.
Old Jun 25, 2006 | 02:24 PM
Nisif's Avatar
Default Re: Crx Si Seats into Hatch: Swap pans or Weld rails? (91civicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicEX &raquo;</TD></TR><TR><TD CLASS="quote">dont jb weld your fawking seats man. if you ever get in a accident or even brake too hard theyre comin off. u need to make custom brakets. or find some hatch si seats</TD></TR></TABLE>
I was kidding about the jb weld
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0crxG0 &raquo;</TD></TR><TR><TD CLASS="quote">Hope you getem in there man!
I noticed there's a CRX/Civic Video Thread stickied to the top of our forum, so you/me could post it there w/o problems</TD></TR></TABLE>
Thanks, I've never uploaded a video, if you wouldn't mind doing so that'll be great, whenever you get a chance at least, no rush
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxblues &raquo;</TD></TR><TR><TD CLASS="quote">swap the pans its not that hard. </TD></TR></TABLE>
Swapping the pans isn't that hard, but if I use my Dx pans then I have to fab up something with hardware that attaches the seatback for the si seats, kind of hard to explain, if I have the time I'll try to do a write up on this with pics
724chris
12
Aug 10, 2009 03:17 PM
PuroMotor
Feb 4, 2009 06:27 AM
CivicRaping
Aug 9, 2005 04:30 AM
jedubz
Jul 29, 2004 05:34 AM
Louie B.
Mar 10, 2002 03:52 PM
