Running radiator fan all the time.
Old Jun 22, 2006 | 07:15 PM
Boostage's Avatar
Default Running radiator fan all the time.
Is there anything negative about jumping your fan to run all the time? I have a turbo setup and the IC is blocking flow to the radiator. I currently have the fan on constantly, and after hard pulls then running up into stop and go traffic the temps slowly climb.
if I pull over and splash a little water on the radiator the needle drops back down so I know for sure that the problem is teh radiator isnt getting enough air to cool it. now I want to add a second fan as a pusher, to suppliment the puller. and have them run constantly. will this be a problem?
Old Jun 22, 2006 | 08:06 PM
fms1day's Avatar
Default Re: Running radiator fan all the time. (Boostage)
having the exact same problem with the over heating on a turbo car as you.. bump for you
Old Jun 22, 2006 | 08:19 PM
SuperSteve737's Avatar
I didn't have any problems when I wired my fan to be on all the time. It's electric, not mechanical.
Old Jun 22, 2006 | 08:24 PM
TylerB's Avatar
Mine unfortunately is on a switch because it decided It didn't want to work on its own. 3 months on a relayed switch, no problems here.
Old Jun 22, 2006 | 08:51 PM
swap_killer7079's Avatar
Default Re: Running radiator fan all the time. (EGG#)
yea mine done the same thing, my fan never kicked on and my car ran a lil hot but nothing too bad, but i hooked the fan up to a toggle that was a month ago. it still warms up fine because the thermostat doesnt let the water flow until 180degrees anyways, you should be ok.
Old Jun 22, 2006 | 09:11 PM
EeeJayEight's Avatar
Default Re: Running radiator fan all the time. (swap_killer7079)
my dad has done this to several cars.. on all the time & also switched.. never had a problem
Old Jun 22, 2006 | 09:40 PM
fmrprojects's Avatar
Default Re: Running radiator fan all the time. (EeeJayEight)
just replace the fan switch
91EF919
Apr 4, 2009 12:12 PM
TomIntegraGSR
Jun 10, 2007 06:23 PM
mike93eh
Mar 26, 2005 03:04 PM
