AEM EMS Battery Voltage Compensation Question... 1050 BOX...
Old Jun 22, 2006 | 04:21 PM
kdawgy2k1's Avatar
Default AEM EMS Battery Voltage Compensation Question... 1050 BOX...
Grrrr.... To get to the point, does anyone have any idea how to tune this map... To make a long story short, I'm having drivability issues when i turn on my FACTORY fogg lights with yellow H3 bulbs... Right now the map is tuned at base line numbers from the "Turbo Integra 440cc" Map from the AEM Software...
Which is as follows...
14V--660 13V--800 12V--920 11V--1050 10V--1270 9V--1530
Basically when the lights are OFF the cars drives pretty much smooth... But when i turn on the Inner Fog Lights ( DA Integra ) the car begins to hesitate pretty bad and runs like the car is REALLY REALLY rich and will not run smooth unless there is a DECENT LOAD put on the Engine...
Any Help Would Greatly be appreciated and anyone in the area that is a GOOD GOOD EMS Tuner will be PAID IN CASH if I need to come see you and let you do your thang... LOL ITS KILLING ME...
Kellen
Old Jun 22, 2006 | 04:32 PM
tony1's Avatar
Default Re: AEM EMS Battery Voltage Compensation Question... 1050 BOX... (kdawgy2k1)
What does the battery voltage do when you turn the lights on?
Old Jun 22, 2006 | 04:50 PM
Mase's Avatar
well,
first off, if its running that bad, i suggest you take it to a tuner ASAP. it sounds like it just needs to be tuned correctly
second, what Firmware are you running?
and do you even have 440cc injectors?
and like tony said, what is your voltage differences between lights off and on?
Old Jun 22, 2006 | 04:53 PM
kdawgy2k1's Avatar
When I'm at idle the car runs at 14.1 to 14.2 Volts... When i turn on my normal driving lights at idle the car idles at about 14.0 Volts when the foggs are turne on the Voltage drops to about 13.5 to 13.8ish or 13.9ish... But when im driving the battery voltage stays at 14.1 to 14.2 unless im at a light with my foot on the brakes or at idle and again it drops to 13.5-13.8 when the foggs are on...
The voltage numbers im giving to you are comming from my BLITZ turbo timer... FATT 3
Old Jun 22, 2006 | 04:55 PM
kdawgy2k1's Avatar
Im using Seimens/Decka 780cc Injectors... and Firmware 3.18 I beleive...
Old Jun 22, 2006 | 05:00 PM
Mase's Avatar
Default Re: (kdawgy2k1)
before you do anything else, change ur battery offset for those injectors.
then tune the fuel map and see if that fixes the problem
Old Jun 22, 2006 | 05:04 PM
kdawgy2k1's Avatar
Will do... I think Im gonna go back to the shop now and see what happens... Thanks alot and I will be back with more info on the results...
ashtons300zx
May 28, 2012 08:01 AM
RACEPAK
Engine Management and Tuning
Jul 29, 2009 07:11 AM
kdawgy2k1
Jun 22, 2006 06:56 PM
kdawgy2k1
May 19, 2006 02:38 PM
