Steering wheel/horn HELP!! SEARCHED!!
Old Jun 22, 2006 | 04:06 PM
c.dub's Avatar
Default Steering wheel/horn HELP!! SEARCHED!!
Okay so I have a Spacro hub and a knock off Type R style steering wheel. I hooked up the hub into the teeth properly, and hooked up the black ground wire, but the horn doesn't work. I searched and read that there is apparently a second red wire? Well when I slid my stock wheel off there was no wire. Is it inside the stock wheel? If so, where does this wire go anyways? I know one end will go on the second prong of the horn, but what about the other end?
Help!!
Old Jun 22, 2006 | 04:34 PM
c.dub's Avatar
Default Re: Steering wheel/horn HELP!! SEARCHED!! (deviate_si)
Ok so someone must know what is going on... I took some black wire hooked up to a brass O ring out of my stock wheel, but I don't get how this is supposed to fit on with the hub. There's nowheres I can really feed the wire, and I don't know how to make the O ring fit....
Old Jun 22, 2006 | 04:42 PM
c.dub's Avatar
Bump I'm sitting in my garage trying to figure this **** out...
Old Jun 22, 2006 | 05:57 PM
c.dub's Avatar
Bump again.....
Old Jun 22, 2006 | 06:40 PM
c.dub's Avatar
Default Re: Steering wheel/horn HELP!! SEARCHED!! (aallbbeerrtttttt)
Good idea but still doesn't help
This is probably something retarded and small that I'm just not getting. All the archived stuff has outdated pics, so it's not helping.
Old Jun 22, 2006 | 06:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
All the horn should need to work is for the wire coming
from the steering column to be grounded..
It is possible that the horn switch is not making good contact
or the wheel itself is not grounded..
Old Jun 22, 2006 | 07:09 PM
RasmusRic's Avatar
Default Re: Steering wheel/horn HELP!! SEARCHED!! (88DXCRX)
i going to assume that you checked your fuses? did you test the horn before you started and did you try to put the old wheel back on to test it?
Old Jun 22, 2006 | 07:19 PM
c.dub's Avatar
Default Re: Steering wheel/horn HELP!! SEARCHED!! (RasmusRic)
I tested it, the horn works. I thought it might have been the button though.
This is what I have connected:
The black wire that comes attached to my hub, is conneted to one of two prongs on the horn. The hub is sitting on the steering column how it should.
What I'm trying to figure out is what is going on in this picture:
I'm going to go try a second horn my friend has from his Sparco wheel.
Modified by deviate_si at 7:32 AM 6/23/2006
Old Jun 22, 2006 | 10:32 PM
c.dub's Avatar
Bump
crdcz03
Sep 10, 2020 09:23 PM
saikouEF8
Jun 13, 2006 05:03 PM
Sic_DA_Nine
Jan 29, 2006 09:06 AM
mahatma
10
Jul 11, 2005 08:18 AM
98GeeYes-Are
10
May 6, 2004 11:36 PM
