need info on the OBD0 SOHC ZC
I'm a little frustrated right now having searched a bunch of forums for information on this engine, specifically, what year make model it comes from in Japan. Tons of info on the DOHC, a little bit on the OBD1 SOHC ZC Vtec, OBD2 and D15B engines, but none on this engine.
Previous owner swapped this non-VTEC SOHC OBD0 "ZC" motor into my 90 Civic Si. Then a lady hit my car, and the insurance is trying to assess it's value. They want info about the motor to prove that it's a low mileage JDM swap as opposed to the factory 200+k motor. I don't have any documentation, but they're willing to give me an estimated mileage around 75k or so if I can prove that the only way to get a ZC motor is to get it shipped from Japan.
I'm going to direct them to call a CA Smog Ref, Honda, and/or an engine importer, but I need the specifics so that they aren't given info on a DOHC or some other motor by mistake. I swear I've seen this info online but I haven't found it in the past hour. I'm pretty sure it didn't come in a Civic, CRX, or Integra.
What year, make, and model does this engine come from? Thanks.
The motor's basically a D16A6 with a handful of more horsepower. Arguably the best engine starting point for our cars, and no one knows anything?
JDM CRX SiR's came with b16's, so no.
can u look on the block and give us the engine code?
a lot easier to search if u have the engine code.
if it says ZC, maybe they did a OBd1-obd0 conversion.
http://www.integra.orcon.net.nz/engines
http://www.answers.com/topic/list-of-honda-engines
They came in the 88-91 (over there it 87-90 I beleive) Civic Si with SOHC, not the DOHC. The engine is a 120hp 1.6L. Exact same as a D16A6, only has better cam, I think like .2 better CR too.
You are better off calling these guys:
http://www.hmotorsonline.com/s...30018
And ask them info about this engine in the link. Phone number at bottom of link I gave you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">They came in the 88-91 (over there it 87-90 I beleive) Civic Si with SOHC, not the DOHC. The engine is a 120hp 1.6L. Exact same as a D16A6, only has better cam, I think like .2 better CR too.
And ask them info about this engine in the link. Phone number at bottom of link I gave you.</TD></TR></TABLE>
you guys are silly.
it came out of the same cars as the dohc.
crx, integra, wagon, etc.....87-91.
its just an A6 with a better cam. come on people.
go to zcresource.com lots of good info there.
(hee hee, didnt see the two posts above......
Modified by SIred91 at 10:12 AM 6/23/2006
)Modified by SIred91 at 10:12 AM 6/23/2006
it came in a lot of different cars including (but not limited to):
88-91 Civic 5 door Shuttle 56i
88-91 Civic 5 door Shuttle RTi
88-91 Civic 4 door sedan 4wd RTiJ
91-92 Civic Ferio RTX - carbed engine
88-94 Civic 5 door Shuttle Beagle
tegracer19
Oct 14, 2007 04:33 PM
