Sliver liquid like stuff on my plugs?
Old Jun 22, 2006 | 02:18 PM
DFW's Avatar
DFW
Default Sliver liquid like stuff on my plugs?
Changed my spark plugs last night and noticed when I pulled them out that there was some sliver liquid substance on them. I don't how to explain how it looks, but it kinda looks like really thin solder right after you melt it. It was just around the top of them, couldnt see it until you touched it.
Old Jun 22, 2006 | 02:20 PM
ffHeart's Avatar
Default Re: Sliver liquid like stuff on my plugs? (DFW)
That silver stuff is anti-seize for your plugs.
Old Jun 22, 2006 | 02:22 PM
DFW's Avatar
DFW
Default Re: Sliver liquid like stuff on my plugs? (whitewonder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitewonder &raquo;</TD></TR><TR><TD CLASS="quote">That silver stuff is anti-seize for your plugs. </TD></TR></TABLE>
Why would it be on there? I never changed the plugs since I got the car till now.
Old Jun 22, 2006 | 02:25 PM
umop-apisdn's Avatar
Anti-seize prevents galling, which aids plug removal. If the plugs are installed without the lubricant, it's possible to remove the threads (from the head) along with the plug when you pull them out.
Old Jun 22, 2006 | 02:30 PM
DFW's Avatar
DFW
Default Re: Sliver liquid like stuff on my plugs? (umop-apisdn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umop-apisdn &raquo;</TD></TR><TR><TD CLASS="quote">Anti-seize prevents galling, which aids plug removal. If the plugs are installed without the lubricant, it's possible to remove the threads (from the head) along with the plug when you pull them out.</TD></TR></TABLE>
Never knew that. Probably should've asked before putting it back in. Oh well shouldn't be a problem.
Thanks for the help.
Old Jun 22, 2006 | 02:34 PM
tatmark1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote"> Oh well shouldn't be a problem.</TD></TR></TABLE>
i wouldnt bet on it. ive been there and done that(even thou i bouht it like that) i will always use anti sieze! you should too!
wesk18
Jan 15, 2008 11:51 PM
rockenuptown
Jun 4, 2007 02:20 PM
Initial DA6
Feb 9, 2006 08:01 PM
Phatch99
Sep 8, 2005 12:39 PM
rice a roni
27
Dec 7, 2003 01:08 PM
