Help a girl with a regular old honda civic out!!!!
Hey there...
I don't have a high performance engine or anything special on my car, but I do have a problem and hoped one of you wonderfully knowledgable guys could help with.
Why can't I find the place to put tranny fluid in my engine?? I see two areas to place fluid near the firewall but they are both labeled brake fluid. Please help!!!!! By the way, I have a 95' Civic
There are two places where you can fill your transmission:
1.) is to remove the speed sensor, and pour it in there using a funnel
2.) there is a bolt on the side of the transmission, which you can remove and pump in the fluid.
Neither are labeled.
it's it's a manual transmission, make sure to use Honda MTF.
THANK YOU DAVE... I really appreciate your help. And they are not labeled cause I've been trying to find them. Is the speed sensor easy to find and remove? I kinda need to do it myself and was hoping it would be easy.
yah know if a guy made a post like this it would be flamed to the point of no return.....
Anyway, it's easier to pull the check bolt in the side and use a funnel with a hose attached to it IMO.
that is if you have a manual trans, auto trans is different.
if you look above the drain bolt a little closer to the back of the tranny there is a big 17mm nut. that is the fill plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">yah know if a guy made a post like this it would be flamed to the point of no return.....</TD></TR></TABLE>
no ****..but since it's a girl, we can all prove our manliness instead...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corrie »</TD></TR><TR><TD CLASS="quote">... I see two areas to place fluid near the firewall but they are both labeled brake fluid. Please help!!!!! By the way, I have a 95' Civic </TD></TR></TABLE>Those are the brake fluid & clutch fluid reservoirs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave »</TD></TR><TR><TD CLASS="quote">Do you have a manual or automatic transmission?</TD></TR></TABLE>Must be manual, since it has a clutch fluid reservoir...
Corrie, have you figured out where the drain & fill plugs are? Drain is directly below the right-side axle; it's got a square hole where you use a socket-wrench handle without any socket. Fill is about at the same elevation as the axle, but behind it. The fill plug uses a regular wrench (maybe 17mm?), but it's bigger than all the other bolts which hold the tranny case together.
Amiduffer
Oct 19, 2007 01:27 PM
joekrz
14
May 8, 2007 07:09 AM
