Oil pan gasket replacement
Old Jun 21, 2006 | 08:53 PM
KillerBee18's Avatar
Default Oil pan gasket replacement
Just recently the oil pan gasket began to leak from the side the transmission connects with so i pulled the thin metal plate that covers the exposed part of the flywheel and a oil pan bolt drops out. The other bolt/nuts around it were also loose, so i tightend them back up and plan on replacing it next time i change to oil since the oil was changed recently. The question is, anyone else have this problem and i was just seeing if putting threadlock on the nuts and blots before installing the new gasket will help, because the torque spec is not really that tight (8.7 ft/lbs). I was just seeing if anyone else had this problem and tried using threadlocker.
Old Jun 22, 2006 | 12:18 AM
Bleedinh 99Si's Avatar
Default Re: Oil pan gasket replacement (KillerBee18)
Couldn't hurt don't forget to not use sealant on the gasket ...common misconception
Old Jun 22, 2006 | 11:21 AM
SiDonny's Avatar
Default Re: Oil pan gasket replacement (Bleedinh 99Si)
^^ i agree with him.. i also only have mines torqued down @ 8.7 ft/lbs. and it hasn't been leaking for a year now since i last changed my gasket.. there's also a certain order to tighten down the bolts to get an even seal and not distort the gasket
george34
Nov 9, 2016 09:44 PM
My_EFsedan
Apr 2, 2009 11:43 AM
JFG Kevin
Jun 19, 2007 07:33 PM
IntegraB18A
Dec 20, 2003 08:18 PM
MeanGreenEG9
Dec 18, 2002 07:43 PM
