Can valve clearances make that much of a difference?
Old Jun 21, 2006 | 07:41 PM
Civicman86's Avatar
Default Can valve clearances make that much of a difference?
I just installed a cam in my d16. I didnt do the valve clearances yet (doing them tomorrow), but I did start the car to make sure she would fire up. The car is running like **** and almost sounds like the timing is off, but the cam and crank are both in sync at TDC. So my question is, do those clearances really make the car run so shitty?
Old Jun 21, 2006 | 08:06 PM
LeftCorner's Avatar
Default Re: Can valve clearances make that much of a difference? (Civicman86)
Yes, if they're too tight/loose you'll get a condition similar to a misfire. If they're too tight for an extended period it'll eventually burn the valves.
Old Jun 21, 2006 | 08:07 PM
Civicman86's Avatar
Default Re: Can valve clearances make that much of a difference? (LeftCorner)
Well they will be fixed tomorrow. thanks for the response. I went out and both cam/crank are both TDC so it didnt skip. Lets hope its just the clearances.
BTW what part of KY you from?
garyc17
May 4, 2007 08:29 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
Atheist
Aug 10, 2004 07:40 AM
Floyd
Sep 29, 2002 06:41 PM
Resurgent
Sep 5, 2002 12:58 PM
