Finished Swap, Car Won't Start
Old Jun 21, 2006 | 05:02 PM
92b16ahatch's Avatar
Default Finished Swap, Car Won't Start
I just finished putting a OBD-I JDM b16 in a 92 vx and the car won't start. I am getting codes 22 and 41. I get fuel but no spark. I tested the coil and igniter and both were good. All grounds look good. Any help would be appreciated.
Old Jun 21, 2006 | 05:25 PM
Otherguy's Avatar
NASIOC.com
Default Re: Finished Swap, Car Won't Start (92b16ahatch)
22 VTEC pressure valve
41 Primary oxygen sensor heater
Well, double check all your grounds, are the spark plug wires still good? are your spark plugs bad? Have you checked the cap or rotor? What harness are you using? Are all the plugs pluged in right?
Old Jun 21, 2006 | 05:32 PM
Default Re: Finished Swap, Car Won't Start (Otherguy)
I am going to be replacing plugs and wires and the cap and rotor. I am getting power to the distributor but not to the wires. I am using the vx harness.Would either of those codes cause it not to start? Thank for your reply.
Old Jun 21, 2006 | 05:39 PM
e jay one's Avatar
it will start with those codes.
Old Jun 21, 2006 | 05:40 PM
Otherguy's Avatar
NASIOC.com
I take that back, you might need a new Oxygen sensor... Can you take a pic of the vtec solinoid
Old Jun 21, 2006 | 05:42 PM
Default Re: Finished Swap, Car Won't Start (e jay one)
Would the distributor off of the d15z1 work on the b16?
Old Jun 21, 2006 | 05:46 PM
axtran's Avatar
don't think so. b-series dizzy are different.
Old Jun 21, 2006 | 05:59 PM
I can't take a picture right now. I got a universal o2 to convert the 5-wire to 4-wire I just haven't wired it yet. Why would I be getting code 22? Tommorow I'm going to wire up the o2 and replace the plugs, wires, cap, and rotor. Any other suggestions and thanks for the replies.
micah13x
11
Apr 14, 2011 03:09 PM
avargas28
Apr 15, 2009 05:32 PM
bcumby
Dec 15, 2007 02:36 PM
wanna b R
Aug 25, 2004 01:02 PM
96whitels
Aug 19, 2001 02:06 AM
