Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu.
Old Jun 21, 2006 | 04:24 PM
mtber's Avatar
Default Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu.
I made two short videos to help customers out which buy the DIY chip/chipkit we offer.
I figured I would post these vides to help those new to the ecu world
How to remove/install a 28 pin eprom chip in a socketed ecu
How to socket/chip an obd1 ecu
These are just run throughs, they are not actual step by step videos.
If you don't understand what a chipped ecu is or what tuning is etc.
You should click here and read phearable.net's EFI intro guide.
Modified by mtber at 1:42 AM 6/22/2006
Old Jun 28, 2006 | 09:16 AM
slow poke's Avatar
Default Re: Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu. (mtber)
Nice
Old Jul 3, 2006 | 11:12 AM
EnjoyTheRideDC2's Avatar
Default Re: Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu. (slow poke)
Great run throughs. I'm sure many will appreciate the info.
Old Jul 4, 2006 | 12:21 AM
mtber's Avatar
Default Re: Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu. (EnjoyTheRideD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Great run throughs. I'm sure many will appreciate the info. </TD></TR></TABLE>
Glad you liked it
Old Jul 6, 2006 | 06:58 AM
hybridpatient95's Avatar
how do i convert my auto p30 to a 5 speed?
Old Jul 6, 2006 | 09:45 AM
mtber's Avatar
Default Re: (hybridpatient95)
Remove rp18 & rp17 and add a jumper at rp18.
Old Jul 6, 2006 | 07:13 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">.
You should click here and read phearable.net's EFI intro guide.</TD></TR></TABLE>
You forgot P74 LS ecu in your OBD1 non-VTEC list
Old Jul 6, 2006 | 08:37 PM
mtber's Avatar
Default Re: Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu. (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">You forgot P74 LS ecu in your OBD1 non-VTEC list </TD></TR></TABLE>
Old Jul 6, 2006 | 09:42 PM
its a jdm ecu .. not usdm
Old Jul 6, 2006 | 09:51 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridpatient95 &raquo;</TD></TR><TR><TD CLASS="quote">its a jdm ecu .. not usdm </TD></TR></TABLE>
So... ?
Old Jul 6, 2006 | 11:54 PM
Katman's Avatar
simply put a 5speed program on your JDM auto P30 ecu and will become a 5speed ecu. No special jumpers need to be cut or added, just a simple reprogram.
Old Jul 7, 2006 | 12:28 AM
mtber's Avatar
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">simply put a 5speed program on your JDM auto P30 ecu and will become a 5speed ecu. No special jumpers need to be cut or added, just a simple reprogram. </TD></TR></TABLE>
You can still remove rp18 & rp17 and jump rp18 on a jdm ecu.
I have yet to try running a crome rom file on a automatic jdm ecu without performing the hardware conversion.
The reason I have not tried this is all usdm ecus throw a code 19 without performing the hardware conversion on crome...
Old Jul 7, 2006 | 11:12 AM
Katman's Avatar
Default Re: (mtber)
The reason I have not tried this is all usdm ecus throw a code 19 without performing the hardware conversion on crome... </TD></TR></TABLE>
Try it without using Crome
Old Jul 7, 2006 | 11:18 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">Try it without using Crome </TD></TR></TABLE>
I prefer to convert the ecus via the hardware method so I do not have to have my customer's come back to me telling me they are throwing a code 19 due to running a crome rom file.
I have seen plenty of other "ecu chippers" be lazy & not perform this conversion.
Old Jul 7, 2006 | 03:05 PM
Katman's Avatar
Default Re: (mtber)
I have seen plenty of other "ecu chippers" be lazy & not perform this conversion. </TD></TR></TABLE>
word..
to each his own..
Old Jul 8, 2006 | 09:30 PM
powerfulperformance's Avatar
Links don't work.
Old Jul 9, 2006 | 10:39 AM
mtber's Avatar
Default Re: (powerfulperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance &raquo;</TD></TR><TR><TD CLASS="quote">Links don't work.</TD></TR></TABLE>
Yes they do, what error do you see ?
civicsirii
Engine Management and Tuning
Jul 31, 2018 11:36 AM
HdmPowered
Jul 7, 2010 03:42 PM
nudeinthelude
Apr 21, 2008 09:04 PM
mtber
21
Oct 19, 2006 08:58 AM
alfaaay
Apr 7, 2004 12:20 AM
