Installing A/C
Old Apr 17, 2002 | 09:46 AM
OldSchoolHatch's Avatar
Default Installing A/C
Can someone tell me everything I'd need to pull out of a car at a junkyard to install AC, and how much would it cost to have it installed? Or would I be able to do it myself? Please let me know...
Old Apr 17, 2002 | 10:31 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Installing A/C (OldSchoolHatch)
I'm selling the a/c off of my 91 Civic Si. Worked great before I pulled it out.
I have *all* of the underhood parts (bolts, tubes, brackets, etc) that you'd need to make it work. IM or email me if you are interested.
Old Apr 17, 2002 | 11:40 PM
Default Re: Installing A/C (Todd00)
I'm interested, but I don't think I'd have enough to buy it and get it installed. Does anyone know what's involved in installing it or how much it would cost to have it done?
Old Apr 18, 2002 | 08:43 PM
StorminMatt's Avatar
Default Re: Installing A/C (AshlandSi)
Installing A/C is really not that hard at all. I would consider it to be a MUCH easier job than, say, pulling the head on an engine. There are just a few important things to keep in mind. First, replace ALL o-rings with new ones. Even those in the evaporator box on the expansion valve. And when installing new o-rings, lubricate them with FRESH, CLEAN refrigerant oil. Torque all connections to the proper specs with a torque wrench and crow's foot attachment. And when tightening connections, ALWAYS back up the other fitting with a wrench to prevent the lines from twisting. Finally, ALWAYS use a new receiver/dryer. And if you have the system flushed, do so with the old receiver/dryer. Don't put in the new one until after the system is fluched AND right before charging.
cambam20
Apr 10, 2009 04:00 PM
Boost2NA
Jul 28, 2003 05:08 PM
PhatboyNYC
Jul 27, 2002 08:58 PM
GSRdriver
Sep 26, 2001 03:16 PM
