y8 mini-me help :)
y8 head, d15b7 bottom, gonna run obd0 w/ pm6...
what do i run obd0?? ecu/dizz/injectors/resistor box??
as far as vtec wiring, how does the rpm switch work??
and what timing belt would i use in the setup talked about above?
yes that will work better probly but if you want to be cheap. just connect a ground and power to the rpm switch and it will give the vtec a ground at a certain rpm to activate it. simple stuff.
JAYSCRX420
Jul 14, 2018 11:39 AM
audiimportech
Mar 25, 2007 02:17 PM
