? about paint
Old Jun 21, 2006 | 03:02 PM
LootR0435's Avatar
Default ? about paint
I'm painting my JDM front end, PY, the shop wants to know what kind of paint, enamel or polyuerathane, just base (1 step), or base/ clear (2 step). It seems I have read conflicting opinions on here before, any ideas which way is best, which is OEM? Basically, what should I do?
Old Jun 21, 2006 | 03:23 PM
330R's Avatar
Default Re: ? about paint (LootR0435)
I can tell you that it's single stage paint. You probably already know the paint ocde is Y-56.
Old Jun 21, 2006 | 03:25 PM
LootR0435's Avatar
Default Re: ? about paint (330R)
Got the code, thanks for the info on the single stage.
I'm ready to spray this thing and get it on the car.
Old Jun 21, 2006 | 03:39 PM
RGoose18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LootR0435 &raquo;</TD></TR><TR><TD CLASS="quote">Got the code, thanks for the info on the single stage.
I'm ready to spray this thing and get it on the car.</TD></TR></TABLE>
PY is single stage paint, I can't speak for the other colors but PY is. Good luck
Old Jun 21, 2006 | 07:31 PM
JjuuN R's Avatar
Default Re: ? about paint (RGoose18)
i would paint the whole car not just the front end... even if your current paint is a few months old the only way to guarentee that the front end is color matched to the rest of the car is to do it that way. no short cuts
Old Jun 21, 2006 | 07:40 PM
kiddcarbuff's Avatar
if its 2 stage, which results in a mucho better finsih then it can be blended into the rest of the car so it matches pretty well, use a dupont based product such as imron 3000 prep, base clear, wetsand and buff the whole car,i know y56 is single stage, but it can be mixed to 2 stage. , but do w/e, your car
Old Jun 22, 2006 | 12:23 PM
RGoose18's Avatar
Default Re: (kiddcarbuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">if its 2 stage, which results in a mucho better finsih then it can be blended into the rest of the car so it matches pretty well, use a dupont based product such as imron 3000 prep, base clear, wetsand and buff the whole car,i know y56 is single stage, but it can be mixed to 2 stage. , but do w/e, your car</TD></TR></TABLE>
How can he blend the existing single stage paint w/ the newer 2 stage?
Old Jun 22, 2006 | 05:55 PM
dc2r_j's Avatar
Default Re: (RGoose18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LootR0435 &raquo;</TD></TR><TR><TD CLASS="quote"> It seems I have read conflicting opinions on here before, any ideas which way is best, which is OEM? Basically, what should I do?</TD></TR></TABLE>
Well, I am a painter so hopefully you listen carefully to me
The single stage paint will work but most places use a base/clear system that will give you the best finish. I spray the PPG Global line at my shop and I can tell you PY (Y56) in a basecoat clearcoat matches pretty much dead on!
Single stage is cheaper and you don't have to clear it, that is why it is used, and primarily on solid colors only.
I recommend you use a base/clear system and have the shop blend your doors. Any decent shop should blend anyway, but there is no need to paint your whole car. Hope this helps, and good luck!
Old Jun 23, 2006 | 02:28 PM
Default Re: (dc2r_j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2r_j &raquo;</TD></TR><TR><TD CLASS="quote">
I recommend you use a base/clear system and have the shop blend your doors. Any decent shop should blend anyway, but there is no need to paint your whole car. Hope this helps, and good luck! </TD></TR></TABLE>
lol thats what i was getting at but it was like 3 am when i typed it, lol
Old Jun 23, 2006 | 03:19 PM
LootR0435's Avatar
thanks for the advice, I think I'm going to do single stage. I'm really not too concerned with the paint match, as I plan on painting the whole car some sort of gunmetal color in a year or so(sorry PY guys). I would drive around with primer for the next year if it was socially acceptable for a R owner to do so.
Old Jun 23, 2006 | 05:26 PM
330R's Avatar
Default Re: (LootR0435)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LootR0435 &raquo;</TD></TR><TR><TD CLASS="quote">I'm really not too concerned with the paint match, as I plan on painting the whole car some sort of gunmetal color in a year or so(sorry PY guys). </TD></TR></TABLE>
No worries. I like how DC2s look in gunmetal; the JDM Vogue Silver Metallic ITRs are also really sharp.
One less PY makes mine just that more rare, too. :keek:
Old Jun 23, 2006 | 05:30 PM
Mires's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LootR0435 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the advice, I think I'm going to do single stage. I'm really not too concerned with the paint match, as I plan on painting the whole car some sort of gunmetal color in a year or so(sorry PY guys). I would drive around with primer for the next year if it was socially acceptable for a R owner to do so.</TD></TR></TABLE>
Screw it and roll it. Who cares what people think? I'd save money as much as I can. You can put the money you would have spent on the front end to the paint job and get it a little early.
ej6dx
Paint and Body
Oct 23, 2016 09:48 AM
pliskin8
Paint and Body
10
Dec 13, 2009 06:37 PM
AmbiguousCivic
Paint and Body
Feb 3, 2008 01:51 PM
racebucket_eg
Paint and Body
45
Nov 9, 2007 04:14 PM
yOnKiNaToR
Aug 14, 2004 11:15 AM
