parking break adjustment?
Old Jun 21, 2006 | 02:51 PM
nickolas388's Avatar
Default parking break adjustment?
i have a 5th gen lude. and my manual says you need to adjust the e-brake once in a while? how do you go about doing this, because my e-brake does not work at all!
thanks,
-nick
Old Jun 21, 2006 | 03:29 PM
98vtec's Avatar
moderator emeritus
Default Re: parking break adjustment? (nickolas388)
its just like adjusting a throttle cable. Pull your center console off and you will see it. Very simple.
Old Jun 21, 2006 | 03:53 PM
oo thanks. swett. so the center consol just pops right off?
Old Jun 21, 2006 | 04:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (nickolas388)
there are like 5-6 small screws that you need to take out, then take off the panels off that attach to the center console and you should be able to just lift it off.
Old Jun 21, 2006 | 05:49 PM
shutta's Avatar
don't pull the whoel thing off, waste of time. pull out the little change holder type thing right next to you behind the ebrake handle, you can reach it in there and adjust it without taking out any screws..
http://www.hondaautomotivepart...81%29
number 14
Old Jun 22, 2006 | 09:21 AM
hamadiscool's Avatar
Default Re: (shutta)
he has a 5th gen and i am pretty sure the pic u r showing is for a 4th gen
Old Jun 22, 2006 | 09:24 AM
iLude's Avatar
Default Re: (hamadiscool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool &raquo;</TD></TR><TR><TD CLASS="quote">he has a 5th gen and i am pretty sure the pic u r showing is for a 4th gen </TD></TR></TABLE>
More specifically, a 92-93 Prelude
Old Jun 22, 2006 | 02:00 PM
shutta's Avatar
woops, guess I missed that part...
Old Jun 24, 2006 | 04:29 PM
alright i think i got it. but i cant lift the whole thing off because its stuck at where the carpet begins in front of the shifter. damn its pissing me off.
Old Jun 24, 2006 | 05:42 PM
98vtec's Avatar
moderator emeritus
there are two bolts hold it on. You have to take the two pieces off to get to them. They just snap on and off.
Old Jun 26, 2006 | 03:22 PM
Default Re: (98vtec)
thanks for everyones help so far. i got the whole center consol off now. i was loosening and tightening a bolt connected to this rectangular metal peice that holds the 2 cables. idk if anyone knows what im talking a about. it made the e-brake start clicking, and tighten up at all different times. for some reason i think im having a problem with the initial grab. the cables pull from the e-brake to the rear where they then start running under the car. still no e-brake, not even a little is there anything else i can do? i didnt see any other adjustments.
thanks,
-nick
Old Jun 27, 2006 | 01:20 PM
up
Old Jun 28, 2006 | 03:32 PM
comon....over 200 people viewed the thread, and only a handfull can help me out. i need to know this so i can sell the car
Old Jun 29, 2006 | 10:53 AM
bluedlude's Avatar
did you ever think that some jackass drove around w/ the ebrake on and wore the pads down to nothing? or maybe the rear rotors are less than the min thickness? cmon buddy.....
Old Jun 29, 2006 | 11:04 AM
Hawkze_2.3's Avatar
If you really can't accomplish anything tightening the cable inside the car, then you'll have to check the pads, rotors and the the spot where the cable attaches to the rear calipers.
pugphilly
Honda Civic (2006 - 2015)
May 18, 2006 08:18 AM
taunt_spike
Jul 20, 2005 06:05 PM
shortlid
May 21, 2005 03:30 PM
SlowAssAccord
Apr 21, 2004 11:36 AM
yellow blur
Feb 16, 2002 12:34 PM
