exhust system
ur not gonna start taking off cans under ur car and all of a sudden u can chirp 5th..I mean you won't notice a power increase or anything IF there is one...
On the flipside, you can remove the middle one, I THINK... If the car doesn't run after that u'd know I was wrong... but if it's NOT a resonator and it's a cat... and if ur car is ODBII, it won't pass emissions w/o it... I dunno, I'm not goign to give u advice on which one to cut as I'm not positive, don't cut any of them O.o
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">ur not gonna start taking off cans under ur car and all of a sudden u can chirp 5th..I mean you won't notice a power increase or anything IF there is one...
On the flipside, you can remove the middle one, I THINK... If the car doesn't run after that u'd know I was wrong... but if it's NOT a resonator and it's a cat... and if ur car is ODBII, it won't pass emissions w/o it... I dunno, I'm not goign to give u advice on which one to cut as I'm not positive, don't cut any of them O.o</TD></TR></TABLE>
oh man be quiet.
your exhaust system comprises of 3 stages of resonation, first (starting from the motor and moving back) is the catalytic converter, that one is necessary (not because of the environment, i couldent care less) because it muffles the sound and you need it to pass e-tests, next is a resonator, this one's only purpose is to quiet down your car, lastly there is a muffler. do NOT take off anything to increase "power" rather, have a custom bigger exhaust built, with a bigger resonator and a higher flow muffler. but again, you will not have any noticible power gains, you will be louder, leading to the illusion of speed
oh man be quiet.
boosted plinko
Engine Management and Tuning
Feb 18, 2011 10:28 PM
egizzle8
Feb 19, 2005 11:13 AM
