============HELP==========HELP========
Old Jun 20, 2006 | 11:42 PM
itr1244's Avatar
Default ============HELP==========HELP========
Ok. here is my situation.
i have multiple problems here
just rebuilt my B18C5
M22xx,ctr piston,310cc rc,chipped ecu P28
- Car will ONLY start with at least 20% of throttle
- car starts and it dies out right away with no throttle
-[ i can hold/pump the throttle to have my car running] (using my stock ECU)
- i can hold/pump the throttle to have my car running for few seconds and it dies out and the light in my ecu blinks as my PGM-FI relay(under the dash, fuse box) kicks in
when i take the key out or turn ign. off the sound stops.
(running chipped P28 with RM chip,)
- this ECU was working fine on my stock motor
-tried adjusting the idle screw , didnt work
-tried adjusting distubutor, didnt work either
-car has removed 2nd o2 and purge controll because i was running obd1 ecu
any help would be Great
thank you guys
Modified by itr1244 at 4:17 AM 6/21/2006
Old Jun 21, 2006 | 12:15 AM
Reid's Avatar
Global Moderator
Default Re: ============HELP==========HELP======== (itr1244)
It sounds like you just need to get your car tuned.
Old Jun 21, 2006 | 12:16 AM
itr1244's Avatar
Default Re: ============HELP==========HELP======== (Reid)
i hope so. but it wont even stay running
Old Jun 21, 2006 | 12:26 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">i hope so. but it wont even stay running </TD></TR></TABLE>
This isn't uncommon.
Don't worry just yet.
Old Jun 21, 2006 | 12:36 AM
Mythias's Avatar
very common issue. Get your car tuned, and you will see a world of difference. My caR would not idle for more than 10 seconds until I had Jeff Evans tune it.
Old Jun 21, 2006 | 12:40 AM
jdmspoonitr's Avatar
Default Re: ============HELP==========HELP======== (Mythias)
Your car sounds like it is dumping fuel
Old Jun 21, 2006 | 01:19 AM
itr1244's Avatar
Default Re: ============HELP==========HELP======== (jdmspoonitr)
why would the PGM-FI relay kick in tho?
that makes my car stop running when running obd1 ecu
Old Jun 21, 2006 | 01:27 AM
ghettocrxsi's Avatar
You need to get your car tuned. Whats yours fuel pressure set at with those injectors? It will run much better once you lean out the lower rpm.
Old Jun 21, 2006 | 09:29 AM
itr1244's Avatar
Default Re: ============HELP==========HELP======== (ghettocrxsi)
i cant tune it yet. it wont stay running.
my PGM - FI relay wont let my car run anymore than 20 seconds
Old Jun 21, 2006 | 01:49 PM
JjuuN R's Avatar
tune
Old Jun 21, 2006 | 08:48 PM
itr1244's Avatar
the ecu was bad. i got my car to start with my stock obd2 computer and stock injectors.
what could go wrong right now ? if i have CTR pistons and M22xx cams. with stock computer?
i have my map senser disconnected right now and it idles low
when i have the map senser connected it was idling at like 1500 when it was warm
Old Jun 21, 2006 | 09:25 PM
With the map hooked up is it throwing a check light? You should be fine with those cams and pistons if you are not reving high and hitting vtec.
Try to find a different obd 1 computer and put that rom in it. It could have a bad program or that ecu could have been fried when they chipped it.
Your car should idle really low with no map sensor.
Old Jun 21, 2006 | 09:36 PM
Haleiwa-Brando's Avatar
The M22XX cams are very close in comparison to the M24X cams (which I'm using). Your car is going to idle like crap until it gets tuned.
Old Jun 21, 2006 | 10:27 PM
itr1244's Avatar
Default Re: ============HELP==========HELP======== (Haleiwa-Brando)
anybody know how dangerous it could be running stock itr ecu /injector on
CTR pistons, and the cams/?
Old Jun 21, 2006 | 10:28 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocrxsi &raquo;</TD></TR><TR><TD CLASS="quote">With the map hooked up is it throwing a check light? You should be fine with those cams and pistons if you are not reving high and hitting vtec.
Your car should idle really low with no map sensor.</TD></TR></TABLE>
yeah it's throwing couple codes right now. i have to find out
Old Jun 21, 2006 | 10:53 PM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">The M22XX cams are very close in comparison to the M24X cams (which I'm using). Your car is going to idle like crap until it gets tuned.</TD></TR></TABLE>
the M22's primary lobes are the same as stock ITR's. Idle should be the same but Jeff has the XX's so the idle is gonig to be off a little bit
Old Jun 21, 2006 | 11:05 PM
Default Re: ============HELP==========HELP======== (itralex)
Hmmmm. I was told by Rocket himself that the primaries were the same measurements (M22XX and the M24X).
Old Jun 22, 2006 | 08:48 AM
itr1244's Avatar
gotta love that lumpy muscle car idle lol
thanks guys
Old Jun 23, 2006 | 12:45 PM
MilFhunter001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">anybody know how dangerous it could be running stock itr ecu /injector on
CTR pistons, and the cams/?</TD></TR></TABLE>
You should be good.. Currently i have stock cams, with CTR pistons with stock fuel system. I run 100 octane though. I'm looking for some buddy club IV's and 310's to make use of that damn compression.
Old Jun 23, 2006 | 01:08 PM
itr1244's Avatar
Default Re: ============HELP==========HELP======== (hondabitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabitch &raquo;</TD></TR><TR><TD CLASS="quote">
You should be good.. Currently i have stock cams, with CTR pistons with stock fuel system. I run 100 octane though. I'm looking for some buddy club IV's and 310's to make use of that damn compression.</TD></TR></TABLE>
how long have you had your set up for?
you sure your car's running ok?
how's your idle?
sh!ft
13
Mar 28, 2013 08:03 PM
ryintegra32
Apr 10, 2012 07:32 PM
bow tie
Sep 17, 2007 07:19 PM
itr1244
15
Jun 29, 2006 11:03 PM
itr1244
Jun 21, 2006 03:04 PM
