no crank...just click
i have a 91 civic hatch with mpfi swap. IT has been running perfect since i did the swap last summer. However its getting a little hotter now(weather wise) and I think that the following problem is probably related to the weather.
I drove to work and back today and everything was fine. But tonite i tried cranking it over and there was no click from the starter or anything ..just the ebrake light...engine light, and a few other idiot lights came on with a click at the beginning. And 2 idiot lights stayed on for a bit even after key was removed.
I was told this is main relay related. However i decided to push start it and it started up, then i shut it off to see if it could start under its own power and it cranked over just fine.
I was lucky today but in the future if i cant get it started eventually...what is this problem related to?
Two "easy" things to try.
1) Kick your dash in the area above your left knee - if the main relay goes bad, as they sometimes do, this might wake it up.
2) Get a metal rod (a huge screwdriver, a tire iron, or something even heavier and long at the same time). Find a spot behind the distributor to squeeze it in, aim at the starter and smack it a couple times. If the starter got stuck on a bad spot, this will likely be enough to move it just a bit off that spot, enough to start.
This advice reminds me a scene from "Armageddon":
"This! Is! How! We! Fix! Things! In Russia!!!""
Main relay troubleshooting:
http://www.teirney.net/civic/KnownProblems.htm
http://www.tegger.com/hondafaq....html
I had the same problem, the last post shows how I fixed it, test if you can jump starter, 10 bucks says you can.
https://honda-tech.com/zerothread?id=1561097
So the engine doesn't crank over right? Is that what your saying? If the engine doesn't crank over, here is the solution:
1. Bad battery (but if everything else works fine, and it does crank the engine over without boosting it, it's fine)
2. Bad ground at starter. Sometime a loose ground can disconnect and the electricity won't flow thru the starter, you'll just hear 1 click, that's it.
3. Dead Starter. Easy to check, simply take it off and hot wire it for a split second.
Main relay problem the engine usually just crank over and over and over for about 5-20 minutes, then it will finally connect again and let the fuel pump prime.
ya i remember the fuel pump priming....but it was like u described it, "just one click but starter did nothing" so it must have been on a wierd spot as it has never happened before and hasnt since...thanks again for all the help
its a wierd one....as i dont think its battery....its an oversize 850 cca battery...and always cranks super strong and never had issues even in -50 *Celcius weather. and alternator is b18.....but anyways its going good...but if it happens again ill use everyones wisdom who replied in troubleshooting
