Honda S2000 Honda S2000
Question about rubber lining around rear wheels
Old Jun 20, 2006 | 10:24 PM
ntm's Avatar
ntm
Default Question about rubber lining around rear wheels
hey, i just recently got an s2000 and i noticed that on one side the rubber lining was starting to fall off. i have heard about it trapping moisture and causing rust. should i need to remove those to prevent any problems or glue it back on or something? thanks
Old Jun 20, 2006 | 11:23 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Question about rubber lining around rear wheels (ntm)
Sand that up. Go to Pep Boys and pick up a can of undercarriage coating, or even truck bed liner. Mask everything off and spray away.
If you're talking about the rubber trim, glue it back. =P
Old Jun 21, 2006 | 07:10 AM
ntm's Avatar
ntm
Default Re: Question about rubber lining around rear wheels (FR-MOB: Projekt)
once i spray it with the bedliner, i can just reglue it back on?
Old Jun 21, 2006 | 08:08 AM
Mr. Lucky's Avatar
i took mine off. when i did, there was so much crap in there you wouldn't even believe. i don't see a need for it. it looks better IMO
Old Jun 21, 2006 | 08:19 AM
texx's Avatar
Default Re: Question about rubber lining around rear wheels (FR-MOB: Mr. Lucky)
pull it off!
Old Jun 21, 2006 | 10:49 AM
WowOzYouRock's Avatar
the cause of the rust is that rubber lining itself .. it traps all the dirt in there and that will cause rust in the future ... dont listen to FR-MOB: Projekt cuz he makes everything complicated lol ... all you have to do is remove that lining and youll be rust free
thats the very first thing i do with my Hondas ... i would go voluntarily to every honda dealership and pull each one if i dont get into trouble ROFL
Old Jun 21, 2006 | 10:59 AM
SUPREME!'s Avatar
Default Re: Question about rubber lining around rear wheels (FR-MOB: Jerk)
I think im going to do this. OT is it normal for the front fender liners to rub after the car has supsension? I closed the wheel gap so the car isnt that low. I heard that you can cut a piece off of the fender liner and it wont rub anymore.
Old Jun 21, 2006 | 11:09 AM
Default Re: Question about rubber lining around rear wheels (SUPREME!)
if you dont have a proper offset and the car is lowered, that would mos' def rub .. it rubbed on my car too, but mine was tucked and only when i make a sharp turn..
if it rubbing againts the plastic, let it rub .. dont worry about it .. the tires are doing the cutting for you ...
Old Jun 21, 2006 | 06:29 PM
ntm's Avatar
ntm
sounds good, i'll be pulling it out this weekend then
Old Jun 22, 2006 | 04:56 AM
Mr. Lucky's Avatar
why this weekend. you can go outside and just pull it of in 10 secs. you can't be that busy now...
bluebloodrex
Apr 27, 2011 11:16 AM
rev_it
Jan 12, 2006 08:50 AM
Chillinlikeamofo
Honda S2000
Dec 27, 2004 10:37 AM
type Gendy
18
Dec 9, 2003 05:34 PM
acatak
Mar 30, 2003 12:37 PM
