Low TPS voltage @ WOT - How do I check the sensor ground?
Old Jun 20, 2006 | 06:46 PM
uber_nihilist's Avatar
Default Low TPS voltage @ WOT - How do I check the sensor ground?
Car: 2000 Integra Type-R
Problem: TPS voltage 0.75 volts @ WOT
Does anyone know how to check if the TPS sensor ground wire is good, which I believe is the GRN/BLK wire (the one farthest to the right when looking at the face of the TPS connector). Which wire on the ECU connector do I probe to test this wire? I can't seem to find a GRN/BLK wire on the ECU connector.
Old Jun 20, 2006 | 08:09 PM
postman's Avatar
Default Re: Low TPS voltage @ WOT - How do I check the sensor ground? (uber_nihilist)
try a continuity test to see if it doesnt have a break
Old Jun 20, 2006 | 09:14 PM
mmuller's Avatar
Mad Scientist
Default Re: Low TPS voltage @ WOT - How do I check the sensor ground? (postman)
im pretty sure all the sensors around that area ground on the t- stat
Old Jun 20, 2006 | 10:36 PM
Default Re: Low TPS voltage @ WOT - How do I check the sensor ground? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure all the sensors around that area ground on the t- stat</TD></TR></TABLE>
Thanks! Somehow reading your post got me thinking about all those electrical diagrams in the Service Manual.
So I found it, the TPS along with the IAT, ECT, and primary HO2S sensor all ground to SG2 on the ECM.
It feels like the service manual is laughing at me now...
Old Jun 21, 2006 | 05:31 AM
mmuller's Avatar
Mad Scientist
there you go
existanzcivicb20
Jun 14, 2015 09:33 AM
MJT805
Jun 12, 2009 11:05 AM
z6hatchboy
Feb 3, 2008 07:42 AM
imadigitalgod
Feb 21, 2005 04:28 AM
ferio 95
Dec 10, 2004 09:16 AM
