Need a 'how to' for a/c belt replacement
Can anyone show me how to replace an a/c belt for my 1997 Honda Civic? It seems as if there is some sort of mount that gets in the way, I was wondering how you get around this. Thanks in advance. This is for a d16y5
Yep, you have to remove that mount. I recently installed AEM Tru-power pulleys and haven't installed the new AC belt because it's going to be a pain in the ***. Have you gotten the tensioning pulley loose? I have tried everything and the damn thing won't budge.
ah ok.. exactly what i needed to know.
also, if i were to replace the compressor (the last owner complained of the compressor making a noise, so he removed the belt and disabled a/c), is it simply a plug n play process? i've never dealt with a/c before, i'm assuming i'd just need to remove the lines, take off compressor, put new compressor, attach lines, then recharge a/c?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cold Fyre »</TD></TR><TR><TD CLASS="quote">Yep, you have to remove that mount. I recently installed AEM Tru-power pulleys and haven't installed the new AC belt because it's going to be a pain in the ***. Have you gotten the tensioning pulley loose? I have tried everything and the damn thing won't budge.</TD></TR></TABLE>
I'm having the same problem. I can't get the ac tensioner to loosen up. How do you do it??
vbolz
Sep 9, 2010 07:56 PM
96hb
Mar 20, 2004 09:44 PM
