del sol d16z6wiring harness for b16 swap
Old Jun 20, 2006 | 03:52 PM
ultrablackhatch's Avatar
Default del sol d16z6wiring harness for b16 swap
I wanted to ask if anyone knows if the d16z6 wiring harness will work for a b16a swap into 93delsol. The reason why I am asking is because I read that it's supposed to be a direct swap. If anyone have any suggestions let me know.Thanks
Old Jun 20, 2006 | 03:58 PM
dans_hatch's Avatar
Default Re: del sol d16z6wiring harness for b16 swap (ultrablackhatch)
Depends on the year the sol is. If the sol is OBD1 and the b16 is OBD1 it'll be direct. If it isn't, your gonna have to repin some wires and get a jumper harness or just send your harness to RYWIRE.com and they'll do a complete conversion plug and play. They are honest and they helped me out alot. Ask for Ryan, he's more knowledgable.
Old Jun 20, 2006 | 04:10 PM
Default Re: del sol d16z6wiring harness for b16 swap (dans_hatch)
The engine and car is both obd1. So the d16z6 wiring harness will work right. Thanks for your help and recommendation.
Old Jun 20, 2006 | 05:31 PM
CBEengineering's Avatar
yeah you have to lengthen O2 wires and add a knock sensor if you are using a unchipped ECU but other than that its straight swap
Old Jun 20, 2006 | 07:51 PM
gold_ef's Avatar
Default Re: del sol d16z6wiring harness for b16 swap (CBEengineering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering &raquo;</TD></TR><TR><TD CLASS="quote">yeah you have to lengthen O2 wires and add a knock sensor if you are using a unchipped ECU but other than that its straight swap</TD></TR></TABLE>
and reverse light sensor i believe
93delsolh22
Jul 17, 2011 06:13 PM
Mr_ET
Nov 4, 2009 04:32 AM
a93and07si
Oct 15, 2008 02:00 PM
streetcartuner
Jul 14, 2008 05:08 PM
badboy704
Sep 28, 2007 06:41 AM
