del sol d16z6wiring harness for b16 swap
I wanted to ask if anyone knows if the d16z6 wiring harness will work for a b16a swap into 93delsol. The reason why I am asking is because I read that it's supposed to be a direct swap. If anyone have any suggestions let me know.Thanks
Re: del sol d16z6wiring harness for b16 swap (ultrablackhatch)
Depends on the year the sol is. If the sol is OBD1 and the b16 is OBD1 it'll be direct. If it isn't, your gonna have to repin some wires and get a jumper harness or just send your harness to RYWIRE.com and they'll do a complete conversion plug and play. They are honest and they helped me out alot. Ask for Ryan, he's more knowledgable.
yeah you have to lengthen O2 wires and add a knock sensor if you are using a unchipped ECU but other than that its straight swap
Re: del sol d16z6wiring harness for b16 swap (CBEengineering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering »</TD></TR><TR><TD CLASS="quote">yeah you have to lengthen O2 wires and add a knock sensor if you are using a unchipped ECU but other than that its straight swap</TD></TR></TABLE>
and reverse light sensor i believe
93delsolh22
07-17-2011 06:13 PM
streetcartuner
07-14-2008 05:08 PM
badboy704
09-28-2007 06:41 AM
