2001 Prelude SH STOCK springs
Old Apr 17, 2002 | 06:47 AM
showlude's Avatar
Default 2001 Prelude SH STOCK springs
2001 Prelude SH springs taken off with only 58 miles on the car, so they are practically brand new. No alterations of any kind have been done to the springs (cutting, compressing or anything). They are in perfect shape. Post or email offers.
Old Apr 17, 2002 | 06:57 AM
Daemione's Avatar
Default Re: 2001 Prelude SH STOCK springs (showlude)
Would you mind taking some measurements for me? Free length, # of active coils, spring diameter, wire diameter, etc. . . . .
Looking to settle once & for all how they're different from base springs.
Old Apr 17, 2002 | 06:59 AM
showlude's Avatar
Default Re: 2001 Prelude SH STOCK springs (Daemione)
umm i dont know what the etc's are nore do i know what the difference is from a spring wire and the spring itself
Old Apr 17, 2002 | 01:58 PM
Steppin Razor's Avatar
New User
I'd be interested in those #'s too. If you can, (for front and rear) measure the height of the springs, count the # of coils, and check if the coils are all the same width, or do they get smaller. The difference between the diameter of the spring and the diameter of the wire is: The diameter of the spring is the diameter/width of a coil. The diameter of the wire is how thick the steel is.
Thanks a lot
Old Apr 17, 2002 | 07:54 PM
ELUD THS's Avatar
New User
Default Re: 2001 Prelude SH STOCK springs (Steppin Razor)
id imagine that the type sh would be tighter coils due to the fact that the atts helps it out between cornering, so id imagine that the springs would be compressed more then base.
Old Apr 18, 2002 | 04:33 PM
showlude's Avatar
rear: 14" and 8 coils
front: 15.5" and 12 coiles
Old Apr 19, 2002 | 07:44 AM
New User
Thanks. How about the diameters? The diameter of the coil is pretty easy to measure, but the diameter of the wire could be tricky if you don't have measuring calipers. (If you don't, you could wrap a piece of string around the wire and mark where the end meets back with the string. That will give the circumference, which can be divided by pi).
Thanks for making the effort, it's appreciated.
therealtime
Sep 23, 2009 11:52 AM
IcantDo55
Suspension & Brakes
May 15, 2007 10:49 AM
IcantDo55
Apr 17, 2007 05:49 PM
IcantDo55
Suspension & Brakes
Apr 17, 2007 12:09 PM
sslude
Jan 11, 2003 12:36 PM
