JDM cluster wiring diagram HELP!
Old Jun 20, 2006 | 02:52 PM
SFWDcoupe's Avatar
Default JDM cluster wiring diagram HELP!
I have purchased a JDM EG cluster with the car and car door diagram. Does anyone have a wiring schematic for wiring up the trunk and door ikons?
Old Jun 20, 2006 | 03:57 PM
SFWDcoupe's Avatar
Default Re: JDM cluster wiring diagram HELP! (SFWDcoupe)
bump
Old Jun 20, 2006 | 08:00 PM
BlueIntegraBoy's Avatar
https://honda-tech.com/zerothread?id=1530521
That's for the trunk. For the doors, you will need to splice into the wires for your door sensor and run it to the back of the cluster. Then connect them to the wires in the back. I forgot which wires I ran them to.
Old Jun 21, 2006 | 11:15 AM
SFWDcoupe's Avatar
Default Re: JDM cluster wiring diagram HELP! (BlueIntegraBoy)
how about the door diagram?
Old Jun 21, 2006 | 11:25 AM
midwestdan's Avatar
i have a jdm cluser in my sol that i put in.. what are you putting it in.. civic or a del sol?
Old Jun 21, 2006 | 01:19 PM
SFWDcoupe's Avatar
Default Re: JDM cluster wiring diagram HELP! (midwestdan)
1995 civic ex coupe
Old Jun 21, 2006 | 01:36 PM
FalkenSiR's Avatar
I have an EG9 4 door cluster with 4 open door sensors I haven't found any info on how to wire up the trunk light and door lights, this should help me tho.
The thing is where do you get the green plugs that go on the back of the tach? My cluster has one 7 pin connector, not two... but I can't find the plugs!
Old Jun 22, 2006 | 02:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWDcoupe &raquo;</TD></TR><TR><TD CLASS="quote">how about the door diagram?</TD></TR></TABLE>
The door lights are definitely in the bottom plug. The problem is, I am too lazy to check it out. I believe one door light is the bottom wire and one door is either the wire below or above the trunk light wire.
Old Jun 22, 2006 | 10:39 AM
SFWDcoupe's Avatar
OK, No guessing! i don't wanna fry the cluster. I know there WAS a diagram a while back on google, but the link is bad, NO one out there?
SedanMan206
Sep 12, 2012 06:28 AM
ToiletFetusSushi
Oct 29, 2004 12:34 PM
W0oT
Sep 27, 2004 07:19 PM
