New A/C Compressor
Old Jun 20, 2006 | 12:13 PM
Jesterian's Avatar
Default New A/C Compressor
I need to replace the a/c compressor in my car. I've got the hasport relocation bracket for my stock d-series compressor, but that one has crapped out on me. Will any d-series compressor work for me? That is, are all the d-series compressors basically the same?
Old Jun 20, 2006 | 12:23 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: New A/C Compressor (Jesterian)
There are two different compressors used:
Sanden and Matsushita.
The first step is to find out which one you have,
So look for a tag behind the drivers headlamp or
on the compressor itself.
I believe the lines are different between the two
so if you get a different compressor than what you have now
you would have to change the compressor lines as well.
Old Jun 21, 2006 | 09:23 PM
Jesterian's Avatar
Default Re: New A/C Compressor (88DXCRX)
So I can't just buy any d-series compressor and expect it to work?
Old Jun 22, 2006 | 01:07 PM
Jesterian's Avatar
Bump
Old Jun 24, 2006 | 09:08 AM
BoostedEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">So I can't just buy any d-series compressor and expect it to work?</TD></TR></TABLE>
Nope go check out the hasport website and under the instructions for the efac bracket it has pix of the difference between the sanden and the mits. I beleive mitsu has the lines spread apart
Old Jun 27, 2006 | 01:11 PM
Jesterian's Avatar
Default Re: New A/C Compressor (BoostedEF)
To tell the truth, I'm checking out their website and I can't find a damn thing about the a/c bracket. Funny, cause I know I ordered it directly from hasport. I think I did it over the phone though.
Old Jun 27, 2006 | 01:13 PM
DR's Avatar
DR
Do they use R-12 or R-134?
Old Jun 27, 2006 | 03:17 PM
BoostedEF's Avatar
Default Re: New A/C Compressor (DR)
look what I found under tech support http://hasport.com/Tech/Hasport%20.htm now scroll down to were it says efac and click
Old Jun 27, 2006 | 03:37 PM
antnyc9r1x's Avatar
The two compressors look totally different. My 91 CRX has the Sanden one. I got the AC bracket from Hasport and the AC compressor from ebay. If you need one look for "a9star9a" he sells new compressors and I've had if for two years now and it is still working great. Of course I converted to R134A because R12 is so expensive. It cools my car enough but its up to you and where you live.
Old Jun 27, 2006 | 06:08 PM
Jesterian's Avatar
Default Re: New A/C Compressor (antnyc9r1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEF &raquo;</TD></TR><TR><TD CLASS="quote">look what I found under tech support http://hasport.com/Tech/Hasport%20.htm now scroll down to were it says efac and click </TD></TR></TABLE>
They could make it a little more clear..
Old Jun 28, 2006 | 08:17 AM
Jesterian's Avatar
How much is a used Sanden compressor worth?
Old Jun 28, 2006 | 09:38 AM
civicandy's Avatar
i have a used one from a 91 crx si, and from a 90 std. hatch. both worked great when i pulled them out. if you need one, let me know.
Old Jun 28, 2006 | 10:42 AM
Jonathan_ED3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">How much is a used Sanden compressor worth?</TD></TR></TABLE>
Not much.
Don't buy a used one. Get a new or a rebuilt. And make sure you buy a NEW drier. It's an absolute MUST anytime you open the a/c system.
It has been my experience that the Matsushita equipped cars never quite work as well as the ones with the Sanden compressors. This is after having owned two of each. Of course this could be a unique experience, but I've also heard that the Shita compressors have a higher failure rate.
And the lines ARE different between the two systems.
On the underside of our hoods there's a badge that gives you a compressor # and the manufacturer.
Old Jun 29, 2006 | 06:08 AM
civicandy's Avatar
if it helps, i have to complete a/c systems. agian, they are from a 91 crx si and a 90 std. hatch. i have all the parts/pieces, including the lines. if you need any of it, let me know. i gotta get rid of it, so i'll sell cheap.
baybay
Aug 26, 2018 02:39 PM
jasrams
Honda Civic (2001 - 2005)
Apr 23, 2012 08:59 AM
skimb37
Apr 24, 2006 07:48 PM
N20civicB18
Mar 5, 2006 10:56 AM
freaker
Aug 10, 2005 06:09 PM
