Brake Light Trouble.... please help
Old Jun 20, 2006 | 07:32 AM
SOHCVTECx2's Avatar
Default Brake Light Trouble.... please help
I have a ek hatch, and my brake light doesn't work. I changed all the bulbs and i even changed the switch on the brake pedal, and it still doesn't work. What can i do or look for?
Old Jun 20, 2006 | 07:45 AM
sol2hatch's Avatar
Default Re: Brake Light Trouble.... please help (SOHCVTECx2)
fuse maybe?
Old Jun 20, 2006 | 09:16 AM
B16CivicEX's Avatar
did u use a test lamp and check voltage, you may have a bad lamp socket. trace the wires with 12v lamp
Old Jun 20, 2006 | 10:09 AM
littleredcivic's Avatar
use a meter. you need to also check the ground at the socket. whatever you are missing, may it be power or ground, trace backwards until you find the open wire or short.
Old Jun 20, 2006 | 09:54 PM
Frank Castle's Avatar
some honda's came with a seprate brake switch near the tail lights....(famous for going bad) usually on the driver side. If Your car has on its most likely the problem.
TwoDeereSleds
Honda CR-V & Element
Aug 30, 2017 05:18 PM
Ferng16
Dec 16, 2013 11:42 PM
lickety
Honda Civic (2001 - 2005)
Aug 25, 2013 12:50 PM
civicflow
Oct 17, 2007 03:54 PM
HyBriDcxR
Aug 9, 2003 11:46 AM
