Freshly built motor Wont start. HELP plz?
Old Jun 19, 2006 | 10:18 PM
itr1244's Avatar
Default Freshly built motor Wont start. HELP plz?
-fired the car up. crank, crank, stops.
-retried. samething
-pulled the spark plug out.
-#2 cyl had coolant in it in the combustion chamber
-coolant&vaccum line got mixed up
-fixed the hoese. everything hooked up right
- motor cranks over. sounds alot better than before
- it cranks but wont start.
-getting the fuel for sure now
-maybe no spark . and i guess i do get the air..
what could be wrong with my motor?
please someone help me with check list or anything would be nice.
thanks alot
Old Jun 20, 2006 | 05:29 AM
PrettyLude's Avatar
your not getting fuel or fire? it has to be one of them. how's the compression and timing looking?
Old Jun 20, 2006 | 07:41 AM
JDM knowledge's Avatar
Default Re: Freshly built motor Wont start. HELP plz? (itr1244)
you dont ahve an intake on tha tthing do you. Reason being is that is sounds like your not getting enough air.
Old Jun 20, 2006 | 03:23 PM
TwoRedEGgs's Avatar
Default Re: Freshly built motor Wont start. HELP plz? (JDM knowledge)
Check the firing order (1-3-2-4), check to make sure you have spark,check to make sure the timingbelt is on correclty, pull the plugs out disconect injectors or pull the ground, disconect distributor crank the motor over see if any fluids some out (water/coolant, oil or fuel). If you are getting spark and fuel, the timing is right along with the firsing order then you may want to put a LITTLE oil down the spark plug hole to try and seal it up then try and start it.
WifesVTEC
Jan 31, 2011 04:46 PM
fcbdolphinz
Sep 8, 2009 03:54 PM
Bo0steDC4
Oct 10, 2008 02:31 PM
2kTeg
Feb 12, 2006 06:14 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
