B18A
Old Jun 19, 2006 | 07:31 PM
ChrisUlrich's Avatar
Default B18A
How much boost can this motor handle stock? Say using a 57 trim turbo?
What can you rev out to safely without jeopardizing the bottom end?
Old Jun 20, 2006 | 11:12 AM
QuarterMileMaster's Avatar
Default Re: B18A (ChrisUlrich)
You should post this in the forced induction forum. You'll get a lot better response there and more educated answers. With good tuning <U></U>I've seen people run as much as 15 psi on the stock bottom end. As far as the revving, you shouldn't take it much farther than the 6500 rpm redline otherwise you risk stretching a rod bolt and spinning a bearing or even floating a valve in the top end.
Old Jun 20, 2006 | 11:37 AM
ludesrv's Avatar
With a proper bottom end (good rings/pistons/rods/bearings) with proper fuel management (most turbo setups lean out and blow up, even on low boost) you can hit 10-15PSI with a good setup.
Don't worry about revving the hell. Use the stock red line/cut off. I'd be more worried about boosting the head off the block, 15 year old head bolts are always weak. I'd get a new metal head gasket and some ARP head studs.
Old Jun 20, 2006 | 12:33 PM
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">With a proper bottom end (good rings/pistons/rods/bearings) with proper fuel management (most turbo setups lean out and blow up, even on low boost) you can hit 10-15PSI with a good setup.
Don't worry about revving the hell. Use the stock red line/cut off. I'd be more worried about boosting the head off the block, 15 year old head bolts are always weak. I'd get a new metal head gasket and some ARP head studs.</TD></TR></TABLE>
Old Jun 20, 2006 | 03:42 PM
97grnrs's Avatar
Default Re: (QuarterMileMaster)
i run 11 psi on stock ls.. havent blown it yet.
Old Jun 20, 2006 | 03:52 PM
lsvtecSIrex's Avatar
arp rod bolts made me feel a little safer
Old Jun 20, 2006 | 05:09 PM
Bjorn20's Avatar
Default Re: (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i run 11 psi on stock ls.. havent blown it yet. </TD></TR></TABLE>
thats interesting.... just gives me an idea on how much ill be able to run with a setup
again.... any kind of forced induction is all about tuning. you can run 10-15 pounds on a completely stock block, and with a nice tune it could turn it ok. but tuning can get expensive
Old Jun 20, 2006 | 07:24 PM
CRX_1.8T's Avatar
https://honda-tech.com/zerothread?id=1323059
hey check this thread out, it is strictly LS-T information and you should find it pretty useful.
Old Jun 21, 2006 | 06:34 PM
Default Re: B18A (CRX_1.8T)
Nice signature... you sure all V8s can't hang?
Thanks for the info everyone!
Old Jun 21, 2006 | 06:35 PM
Bjorn20's Avatar
lol the # of cylinders isnt everything
Old Jun 21, 2006 | 06:43 PM
Default Re: B18A (Bjorn20)
Too bad you live so far... i'd love to see if my V8 can hang. haha Sweet signature though! What kinda times you run that? Type R VTEC crack sounds sweet!
Old Jun 21, 2006 | 06:49 PM
Bjorn20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisUlrich &raquo;</TD></TR><TR><TD CLASS="quote">Too bad you live so far... i'd love to see if my V8 can hang. haha Sweet signature though! What kinda times you run that? Type R VTEC crack sounds sweet!</TD></TR></TABLE>
what you got... a pusstang or a thunderbird?
Old Jun 21, 2006 | 07:33 PM
hahahaha
Trans Am
Pusstang. hahaha Not anymore they aren't. They are quite the car these days... even the GTs. Not saying they are insanely fast but they are getting the idea. 03-04 Cobras are no joke man and you can't tell me otherwise. Not saying you can't beat them, and by the signature... you probably crush stock and slightly modified ones. But once they go KB or Whipple... they are a handful. I sure hope your car traps in the 130s!
Modified by ChrisUlrich at 8:47 PM 6/21/2006
Old Jun 21, 2006 | 09:31 PM
IndySporty's Avatar
That's all well and good but you shouldn't be posting on this forum if you respect V8's. That's like passing out VTEC stickers at a mustang expo dude.
Old Jun 22, 2006 | 08:50 AM
Default Re: (IndySporty)
hahahahaha... I actually saw a "VTEC" badge on a 95 Mustang GT once. haha It was purple! Wide tires on the car too...? I wasn't in the Trans Am so I don't know how fast it was.
So cuz I like V8s I can't post here? That's a joke right?
Chris
Old Jun 22, 2006 | 09:17 AM
Default Re: (ChrisUlrich)
Oh yea... on 10lbs of boost in a CRX (B18A motor). Do you think I'll be able to hit anywhere between 106-109 trap speeds?
LovelyEK
May 21, 2010 10:46 PM
Dabrybry
Nov 7, 2008 10:12 PM
zcrx2006
Nov 21, 2007 07:41 AM
GSRCRXsi
22
Jan 12, 2006 03:23 PM
drvfast
Apr 28, 2004 07:37 AM
