Where the main relay located at? plz help
Old Jun 19, 2006 | 05:13 PM
MattsGreenEG's Avatar
Default Where the main relay located at? plz help
need help asap need to know where the main relay is on a 94 prelude. thanx
Old Jun 19, 2006 | 06:33 PM
Twilightepitaph's Avatar
Default Re: Where the main relay located at? plz help (MattsGreenEG)
drivers side under the dash. It is twards the top on the left side of the steering wheel. You will have to pull off the under part of the dash to get to it easier. I couldnt' get mine out with a socket wrench, the space is too small, so the old one is still there with the new one just hangen around. Its a brown box with a grey bottom.
Old Jun 19, 2006 | 07:10 PM
Yield's Avatar
Answer this: where's the search button at?!?!
Old Jun 19, 2006 | 07:13 PM
SteveoBA8's Avatar
Default Re: (Yield)
in this area
Old Jun 20, 2006 | 07:54 AM
Qveon's Avatar
Default Re: (SteveoBA8)
Old Jun 20, 2006 | 12:04 PM
ninja 6's Avatar
Default Re: (Qveon)
i had to remove the gauges on the 4th gen in order to access the 10mm bolt.
Old Jun 20, 2006 | 02:26 PM
Yield's Avatar
You can also just unclip it from the casing and then remove it rather than trying to figure out how to put a screwdriver in there.
Old Jun 21, 2006 | 12:21 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: (Yield)
Before ******* around with anything, try calling the honda dealership to see if your car qualifies for a recall. I heard a lot of the 4th gen Ludes have a recall on the main relay.
Old Jun 21, 2006 | 03:07 PM
iwubmybb4's Avatar
Default Re: (Chief Brody)
it is a BITCH to get to!!!! i couldn't get to the screw so i just ripped that **** off and my new one is just hanging there like mentioned above!
Joe19
Feb 24, 2019 11:48 AM
black94lude
Jun 1, 2010 09:22 PM
el3vate
Jan 11, 2005 01:18 AM
