SOHC & Turbo Parts, Omni Drag Suspension
Old Jun 19, 2006 | 11:20 AM
.dave's Avatar
i HAS questions ?
Default SOHC & Turbo Parts, Omni Drag Suspension
D16Y8 Shortblock - bought it from G3N3R8 (Mike G's brother) last spring. Not sure if it'll run if you drop it in, needs an oil pan as well. $100
D16Y8 Transmission - 45k miles on it I think, bought from a kid in Arizona. I believe it needs a new 2nd gear synchro. This would be perfect for someone that has a SOHC and wants to put in a LSD without having the downtime of their car apart. Y8 transmissions are usually preferred over the older Z6/Si transmissions as the Y8s have stronger steel shift forks. $70
Venom Intake Manifold for D16 engines - Mounted on the car, never used. Brand new, retails for $500+. Make an offer on it. I'd like to get somewhere over $300 for it, which is a steal as I believe that is what the OBX intake manifold (which is a knockoff of this one) goes for, and the Venom is above and beyond a far higher quality piece.
BBK 70mm Honda Throttle Body - Same situation as the Venom manifold. Brand new, I also have a full gasket set for this that hasn't been opened yet. $230
RC 550cc Peak/Hold Injectors - Barely used, selling because I decided to go with 780s instead. $200
Omni Power Drag Suspension for Honda Civic/Acura Integra - 12k front 18k rear spring rates. Pretty much zero weight transfer to the rear when launching/shifting. Driven for about 50 miles on the car. This setup would retail for $750-800. Works with 92-00 Civics and 94-01 Integras. 96-00 Civics require spacers on the rear $600
T3/T4 .53/.60 Turbo - I'm pretty sure this is the size that it is, once again, mounted on the car but never used. Retails for $650 new, willing to sell for $500
Toshiba Satellite Laptop - Intel Celeron processor, not sure how much RAM is on it. Brand new power cable, needs a new battery at some point though. Has a 9-pin serial port and 2 USB ports on the back. This would make a good laptop for tuning as there are several systems out there that require serial ports (AEM, e-Manage, etc). Has a wireless internet card as well. $300
Modified by daveG at 10:53 AM 6/21/2006
Old Jun 21, 2006 | 06:53 AM
.dave's Avatar
i HAS questions ?
Default Re: SOHC & Turbo Parts, Omni Drag Suspension (daveG)
Up
Reego.
Northeast (Sales)
Feb 21, 2011 10:33 AM
.dave
Jun 21, 2006 06:57 PM
egturbo
Jan 30, 2004 09:08 PM
X-Mazda 3 Racer
Apr 28, 2003 04:14 AM
Pengo
Nov 12, 2002 07:14 PM
